Old 06-01-2012, 10:54 PM   #1
Nothinghead
Nothinghead's Avatar
WWII plane exhaust on a truck?
So I was thinking, I love old WWII planes. Wouldn't it be cool to make a truck that has some of those features? That led to this.
What would I have to overcome to make this exhaust on a truck?
http://www.t-birds.be/image/pictures...%20Exhaust.jpg
I would imagine it would have to be just straight non muffled pipes, right? I think I have seen mufflers that are designed to be short and exit out the side of the running boards, but even those are longer than this application would need to be.
I haven't looked that far into it. I know things like back pressure exist, but I do not fully understand them enough to know how that would play into this sort of situation.
So, am I just cray, or would this be a doable project?
79 Blazer 350 TH350 part time 4wd Sold!
86 GMC 1 ton something...
Nothinghead is offline   Reply With Quote
Old 06-01-2012, 11:12 PM   #2
Shane22696
Shane22696's Avatar
Re: WWII plane exhaust on a truck?
People do basically the same thing but exit the pipes out the hood all the time, I don't see why it couldn't be done with some time and money. I don't really see a way to have mufflers though
80 K10 350 4 spd
4 Inch lift, 33 inch BFG M/t
Shane22696 is offline   Reply With Quote
Old 06-01-2012, 11:37 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Old 06-01-2012, 11:46 PM   #4
Shane22696
Shane22696's Avatar
That's awesome, what are they called?
80 K10 350 4 spd
Old 06-02-2012, 04:15 AM   #5
cdowns
cdowns's Avatar
to run an exhaust like that on any vehicle the big worry is killing yourself with carbon monoxide fumes that fill the interior of your vehicle
i've run short zommies with baffels on gassers many years ago// were great for show effect and the look at me factor but after 10minutes you'd b gasping for air and stinkin like exhaust
Old 06-02-2012, 08:48 AM   #6
Nothinghead
Hmm... I hadn't thought of the CO factor at all.
Old 06-02-2012, 09:11 AM   #7
Nothinghead
How loud are Zoomies with baffles?
Old 06-02-2012, 10:55 AM   #8
cableguy0
With anything dumping out the side its going to be loud. It will be especially loud inside the truck. You could sweep the pipes back and dump out before the rear wheel under the bed out the side but its a lot of work to make that style pipe. Basically you would have to drill a hole in the pipe for every pipe you want out each side then weld them all in hoping that everything ends up coming out level and at the same angle.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-02-2012, 11:59 AM   #9
Gumby
Gumby's Avatar
OK I know when Peter from Family Guy put jet fuel in his truck it was able to fly, but that was just TV magic. Using airplane parts will be no different.
Gumby is offline   Reply With Quote
Old 06-02-2012, 02:07 PM   #10
Nothinghead
Hmm... I had thought about over the rear wheels, but that just isn't quite the same aviation kinda look. Oh well. we'll see when I get the rest of my stuff together for the truck.
Old 06-02-2012, 02:41 PM   #11
cableguy0
Over the rear wheels wouldnt be possible. It would end up smashed. Theres just not enough room to make the bends work.
Old 06-04-2012, 09:30 PM   #12
Eddie H.
Eddie H.'s Avatar
Start by finding an Allison or a Rolls Royce Merlin V12 aircraft engine, swapping into the frame rails, then build the truck around it. (I once saw an Allison in a 65 chevelle.)
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 06-04-2012, 09:56 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-04-2012, 10:06 PM   #14
fencepost
fencepost's Avatar
Could build bummy exhaust, or use a electric valve and pipe back up from under the truck to the fender exhaust then split it off into 4 or ever how many on each side. I think fighter pilot themes are really cool when done right.
fencepost is offline   Reply With Quote
Old 06-04-2012, 10:00 PM   #15
Nothinghead
Yeah, I saw that bad boy. With enough time and money, I would be all over that.
Old 06-04-2012, 10:12 PM   #16
Gumby
Gumby's Avatar
I had sort of an idea like that once, take typical long tube headers, swap them left n right and install them upside down, but in the rear, where the flat header flange would bolt to like the lower 1/4 with the exhaust on the other side, so they functioned.
Old 06-06-2012, 12:29 PM   #17
storm9c1
*** That's interesting ***
storm9c1's Avatar
That V12 car is awesome. Anyone can shove a V12 into a car, but an actual Merlin(!), and to have the aviation dash, that rocks.
My favorite WWII aircraft is the Vought F4U-4 Corsair. Though I don't think anyone will be installing a Pratt R2800-18W into a car (or truck) anytime soon. Perhaps as a kid I saw a tractor pull truck with one of these, but haven't seen anything else in a while.
One heck of an engine stand:
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 06-06-2012, 12:40 PM   #18
noonzor
awesome.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
