Old 07-25-2012, 04:31 PM   #1
BigDan3131
BigDan3131's Avatar
My Free Truck-Project Rhino
In the general 60-66 forums I posted about getting a 63-64 for free. When I have time to work on it I will report progress with pics.
Here is what it looks like now.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-26-2012, 12:08 AM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: My Free Truck-Project Rhino
Can't beat free. Looks pretty solid.
Alan's Classic is offline   Reply With Quote
Old 07-26-2012, 03:22 AM   #3
BigDan3131
BigDan3131's Avatar
I found a set of wheels I want to use:http://www.jegs.com/i/Weld-Racing/92...rentProductId= Its just a matter of how big I want to go. I could just buys these: http://www.jegs.com/i/Mickey-Thompso...rentProductId= and then paint them to match. If I do the MT wheels it would be 16x8's and 16x12's.
Old 07-28-2012, 02:32 PM   #4
C@rnut001
Looks like a great start and especially for free! Good luck on your build with her....
C@rnut001 is offline   Reply With Quote
Old 08-05-2012, 06:20 PM   #5
BigDan3131
BigDan3131's Avatar
I found a pair of seats that should fit nicely. They are from a Nissan NV1500 Van they are just the right height to fit. I will probably build a center console from 1 3/8" tubing to mount a new pro stick shifter and a pair of cup holders.
I plan to Rhino line a large potion of the inside and outside and use it as both a driver and a display vehicle for the different uses you can use liner for.
Old 08-09-2012, 02:10 AM   #6
BigDan3131
BigDan3131's Avatar
I power washed the truck today and the green mold is gone along with minor grease in the engine compartment. I started figuring out my drive train...mostly which trans & engine.
Trans will be a built TH350 able to handle up to 700HP
I have a shop I can go to that will take the powerglide as a partial trade for the work.
The engine on the other hand will be a stock bore and stroke 5.3L with this intake:http://www.jegs.com/i/Holley/510/300...ductId=1646023 and a pair of 600 cfm carbs. More than likely a pair of shiny DP's since I have one already laying aside.
Cam will be from Comp:
Duration @ .050” 239°/243°
Lift with 1.7 Rockers .624“/.624“
Lobe Sep. Angle 109°
Last edited by BigDan3131; 08-18-2012 at 03:19 AM. Reason: Old manifold choice will not work out.
Old 08-10-2012, 12:36 AM   #7
Captainfab
60-66 Nut
So you're planning on keeping this truck 8 lug?
They sure are proud of those Welds
Old 08-12-2012, 04:05 AM   #8
BigDan3131
BigDan3131's Avatar
Yeah I'm staying 8 lug and the welds are kinda pricey so I'm leaning towards XD Wheels like these:http://www.4wheelparts.com/Wheels/XD...XD79889080712N and these: http://www.4wheelparts.com/Wheels/XD...PXD80389080700 the last ones would be painted to match the vehicle not left like they are. Paint wise I'm really leaning towards purple base with rootbeer candy. It looks like the burned orange.
Old 08-18-2012, 03:09 AM   #9
BigDan3131
BigDan3131's Avatar
I took more pictures and the one with the tape lines showing a curved line is where the Rhino will end. So just the upper half will be done in normal paints. Since the rhino can be painted over...I just might.
Next weekend I will be walnut blasting and epoxy primering. The front fenders may or may not be replaced due to the rusted out bottoms but the hood will be gone due to the cost of the replacement panel cost and want of a glass hood.
Old 09-03-2012, 03:41 AM   #10
BigDan3131
BigDan3131's Avatar
I've decided to start small and work my way outward. I pulled up the floor mat to find holes in the usual locations and loose flaky rust over most of the floor. Tomorrow I will be killing the rust with a NAPA brand rust killer which works great as I have used it for years. I will take a few photo's of the before and after treatment and of my fiberglass repairs.
It goes like this, kill the rust and wait 24 hours for it to cure. Then sand the floor not covered in rust followed by at least two coats of fiberglass resin. Let that cure then scuff/sand it with 36 grit and apply more resin along with heavy mat cut to fit each rusted out area. Once all the holes have been filled and smoothed with the 36 grit I will shoot Rhino over the entire floor.
Old 09-03-2012, 03:54 AM   #11
Bazooka
Keepin it old school
Bazooka's Avatar
I really like these
Bazooka is offline   Reply With Quote
Old 09-03-2012, 08:10 AM   #12
niterider65
niterider65's Avatar
mmmm man the left front fender look like the po thought it was cheaper to reform the front of the fender in bondo . looks a little thick
niterider65 is offline   Reply With Quote
Old 09-03-2012, 09:38 AM   #13
awbrown
Smile Re: My Free Truck-Project Rhino
That is the instant fender kit ..........
awbrown is offline   Reply With Quote
Old 12-20-2013, 12:40 AM   #14
Lowl!f3
Lowl!f3's Avatar
Looks like $200 in bondo lol.
Lowl!f3 is offline   Reply With Quote
Old 09-03-2012, 02:00 PM   #15
shok
It's fender in a can!
1966 C10 250 with 3 on the tree Build Thread
Bunch of other cars no one cares about
shok is offline   Reply With Quote
Old 09-06-2012, 01:44 AM   #16
BigDan3131
BigDan3131's Avatar
I am the 3rd owner the second owner was 16 when it was given to him by his Dad and he did that wonderful body work. Here are the before pics of the floor.
Old 09-06-2012, 01:46 AM   #17
BigDan3131
BigDan3131's Avatar
Here are the after rust treatment.
Old 09-06-2012, 02:05 AM   #18
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-07-2012, 02:23 AM   #19
BigDan3131
BigDan3131's Avatar
I'm replacing both front fenders and the hood with fiberglass parts. I will be moving the batteries to the rear and the stock tanks are all going bye bye.
Old 01-20-2013, 12:33 AM   #20
BigDan3131
BigDan3131's Avatar
Since it started raining its been tough to spend time on it. The last thing I did was use resin to seal in all the rusted out areas. Work is way too busy for me right now, I have a full frame off resto of a 1958 Ford Custom 300 and after that is a 48 Ford Tudor. I know I know...They are both owned by the same guy besides its better than being unemployed. Friday I found out I have a 55 Chevy pickup to do sometime this summer.
Back to the truck, I was going to do a 6.0L but since they are so much $$$ I have decided to go another route. So instead it will be a 5.3 with a 6-71 on it with two 650DP's and no hood. I'm keeping the 8 lugs to be different and since the former owner just put $600.00 into the brakes.
Old 01-22-2013, 12:46 AM   #21
BigDan3131
BigDan3131's Avatar
I got the bug to do some work on it. I got the glass laid out on the drivers side and resin laid over it. One more area to cover and another coat of resin and the drivers side is done until rhino lined.
Old 01-31-2013, 04:41 AM   #22
BigDan3131
BigDan3131's Avatar
I made a decision about the truck.
At first it was just going to be a short term fixer to sell for other projects. Then it was going to be a bad blown toy. I have decided to turn it into a full time daily driver to replace my aging S10. So it will be getting either the 6.0L like I had planned with the dual carbs or more than likely a 5.3L with two smaller carbs on same manifold from Holley. Instead of a 4L60E or 4L80E it will get a TH200R4 built to handle five or six hundred horsepower, for a future turbo upgrade. It will get A/C and power steering and brakes none of which were in my original plans. I'm having classic dash take a blank chevy one and drill it for my tastes in gauges which even include a clock. I don't see any reason I can't get good gas mileage out of it with the right gearing, OD and tire height along with cruise control.
Old 02-02-2013, 03:46 AM   #23
Crx150zc
Nice, I love seeing build threds like this
Crx150zc is offline   Reply With Quote
Old 03-06-2013, 03:30 AM   #24
BigDan3131
BigDan3131's Avatar
Well as it turns out the truck is actually a 65 because today I was handed the title. Along with a copy of the build sheet and the original handbook. The two things I'm happiest about are the 4.10 gears and the locker to go with it.
I was at that 6066guy website and found the 305 that was in it weighed about 800 pounds dropping my now engine free chassis to a neat 3530 pounds. After relocating the batteries to the rear which is like removing weight from the vehicle it will feel lighter but not. The saddle tanks and stock tank will go bye-bye shedding some more weight and adding a glass hood will drop it a bit more. I figure with me and the LS in it I should be at 3850 pounds.
Old 06-12-2013, 02:40 AM   #25
BigDan3131
BigDan3131's Avatar
Money is tighter than before and I have decided to now keep the saddle tanks but relocate them to inside the bed with a cross over line so both tanks become one 32 gallon tank.
This weekend is out I have a 53 Chevy Bel Air side job I'm working on for a motor build and of course its Fathers Day Sunday...Happy Fathers Day to you Dads out there.
Here is a link to the color the upper half of the truck will be: http://stevesharpphotography.files.w...cover_blog.jpg Its called Cocoa Powder Pearl by HoK.
