03-20-2002, 11:23 AM | #1 |
HELP ME DECODE WHAT KIND OF REAREND I HAVE.
Hey guys i pulled the pan off my 68 GMC 1/2 ton to change the gear oil, and I found a number on the middle gear and i was wondering if someone could help me decode it. It is a 10 bolt Dana geared rearend. Any info on these rearends would be appreciated here is the number
11 14 66 DANA 30060 A3047 43-14. |
03-20-2002, 01:06 PM | #2 |
I *think* it's a Dana 60 with 3.07 gears.
Anyone confirm? ------------------ Bowen '68 K20 fleet '69 K10 swb fleet '72 C10 lwb step
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
03-20-2002, 01:09 PM | #3 |
computer illiterate
my guess is its a dana 44. I think the dana 60's are 12 bolt
72 2wd blazer 72 swb 4x4 |
03-20-2002, 01:33 PM | #4 |
Dana 60s are also 10 bolt, along with the Dana 70s.
03-20-2002, 02:02 PM | #5 |
Hollanders shows it as a Dana 44. 30060 is the part number for the gear. This is going to be an overkill(but easy to cut-n-paste) but the following is were Dana 44's were used that you could use the ring and pinion out of with your 3-series carrier if you wanted to change them:
BLAZER/JIMMY (full size) 69-72 front axle BLAZER/JIMMY (full size) 73-76 front axle, 3.07 thru 3.73 ratios BLAZER/JIMMY (full size) 77 front axle, Spicer, 3.07 thru 3.73 ratios BLAZER/JIMMY (full size) 78-80 front axle, Spicer, 2.76 thru 3.73 ratios BRONCO 71 Front Axle; Spicer 44 (from ser. K20001), 3.54 ratio BRONCO 72-77 Front Axle; 3.54 ratio CJ-SERIES 72-75 Rear Axle; 3.73 ratio CJ-SERIES 86 Rear Axle; 10 bolt cover, w/o 4.09 ratio CHEROKEE 74-78 Rear Axle; 3.07 and 3.54 ratios CHEROKEE 74-79 Front Axle; 3.07 and 3.54 ratios CHEROKEE 79 Rear Axle; 3.54 ratio CHEROKEE 80-83 Front Axle CHEROKEE 88-90 Rear Axle; Spicer 44 CHEVROLET PICKUP TRUCK 65-67 10 Series; 4x2, 10 bolt cover CHEVROLET PICKUP TRUCK 65-72 10 Series; 4x4, front axle CHEVROLET PICKUP TRUCK 68 10 Series; 4x2, 10 bolt cover, Spicer 44 CHEVROLET PICKUP TRUCK 69-70 20 Series; 4x4, front axle, 3.07, 3.73 and 3.54 CHEVROLET PICKUP TRUCK 73-76 10 Series; 4x4, front axle, 3.07 and 3.73 ratios CHEVROLET PICKUP TRUCK 77-80 10 Series; 4x4, front axle, Spicer, 2.76 thru 3.73 ratios CHEVROLET PICKUP TRUCK 78-80 20 Series; 4x4, front axle, Spicer, 2.76 thru 3.73 ratios COMANCHE 87 Rear Axle; Spicer 44, 3.54 ratio COMANCHE 88-90 Rear Axle; Spicer 44, 3.07 and 3.54 ratios COMANCHE 91-92 Rear Axle; Spicer 44, 3.07 ratio DJ-SERIES 72-73 Rear Axle; 3.73 ratio DODGE PICKUP TRUCK 69-71 200 Series 4x4 (W models); front axle, 3.54 ratio DODGE PICKUP TRUCK 69-74 100 Series 4x4 (W models); front axle, 3.54 ratio DODGE PICKUP TRUCK 75-78 100 Series 4x4 (W models); front axle, 3.23 and 3.54 ratios DODGE PICKUP TRUCK 79-80 100 Series 4x4 (W models); front axle DODGE PICKUP TRUCK 80 200 Series 4x4 (W models); front axle, Spicer 44, 3.54 ratio DODGE PICKUP TRUCK 81-82 250 Series 4x4 (W models); front axle, Spicer 44, 3.54 ratio DODGE PICKUP TRUCK 81-84 150 Series 4x4 (W models); front axle DODGE PICKUP TRUCK 83-84 250 Series 4x4 (W models); front axle, 3.54 ratio DODGE PICKUP TRUCK 84 100 Series 4x4 (W models); front axle FORD PICKUP TRUCK 66 Rear Axle, F100; non-removable carrier, Spicer 44, 26 spline pinion (44-3), 3.31, 3.54 and 3.73 ratios FORD PICKUP TRUCK 67-68 Rear Axle, F100; non-removable carrier, Spicer 44, 3.31, 3.54 and 3.73 ratios FORD PICKUP TRUCK 77 Front Axle, F250; Regular Cab, from ser. Y20001 (2 leaf), 3.54 ratio, 3550 lb. axle FORD PICKUP TRUCK 77 Front Axle, F250; Regular Cab, thru ser. Y20000 (6 leaf), 3.54 ratio FORD PICKUP TRUCK 77-79 Rear Axle, F100; non-removable carrier FORD PICKUP TRUCK 77-79 Rear Axle, F150; non-removable carrier GMC PICKUP TRUCK 63 1000 Series; 4x2, Spicer 44 GMC PICKUP TRUCK 63-66 1000 Series; 4x4 (front & rear axle) GMC PICKUP TRUCK 64-66 1000 Series; 4x2, Spicer 44, 3.07, 3.73 and 3.54 ratios GMC PICKUP TRUCK 67 1500 Series; 4x2, 10 bolt cover, Spicer 44, 3.07, 3.73 and 3.54 ratios GMC PICKUP TRUCK 67-68 1500 Series; 4x4, rear axle, 10 bolt cover GMC PICKUP TRUCK 67-72 1500 Series; 4x4, front axle GMC PICKUP TRUCK 68 1500 Series; 4x2, 10 bolt cover, Spicer 44, 3/8" bolt, 3.07, 3.73 and 3.54 ratios GMC PICKUP TRUCK 71-72 2500 Series; 4x4, front axle, 3.07, 3.54 and 3.73 ratios GMC PICKUP TRUCK 73-76 1500 Series; 4x4, front axle, 3.07 and 3.73 ratios GMC PICKUP TRUCK 77-80 1500 Series; 4x4, front axle, Spicer, 2.76 thru 3.73 ratios GMC PICKUP TRUCK 78-80 2500 Series; 4x4, front axle, Spicer, 2.76 thru 3.73 ratios GRAND WAGONEER 84-91 Front Axle GRAND WAGONEER 86 Rear Axle; 10 bolt cover GRAND WAGONEER 87-91 Rear Axle INTERNATIONAL 67-68 Pickup & Travelall, Rear Axle; 1000B-C and 1100B-C, Spicer 44, 3.31 thru 3.73 ratios INTERNATIONAL 67-68 Pickup & Travelall, Rear Axle; 908B and 908C INTERNATIONAL 69-70 Pickup & Travelall, Rear Axle; 1000D and 1100D, Spicer 44, 3.07 thru 3.73 ratios INTERNATIONAL 69-73 Pickup & Travelall, Front Axle; 1100, 1110 mdls., 3.54 and 3.73 ratios INTERNATIONAL 69-73 Pickup & Travelall, Front Axle; 1200 and 1210 mdls., 3.73 ratio INTERNATIONAL 71-73 Pickup & Travelall, Rear Axle; 1010 and 1110, Spicer 44, 3.07 thru 3.73 ratios INTERNATIONAL 74 Pickup & Travelall, Front Axle; 100 mdls., 3.54 and 3.73 ratios INTERNATIONAL 74-75 Pickup & Travelall, Front Axle; 200 mdls., std. duty axle, 3.73 ratio INTERNATIONAL 74-75 Pickup & Travelall, Rear Axle; 100 and 150 mdls., Spicer 44, 3.07 thru 3.73 ratios INTERNATIONAL 75 Pickup & Travelall, Front Axle; 150 mdls., 3.07 thru 3.73 ratios J-SERIES TRUCK 73 Front Axle; 3.73 ratio J-SERIES TRUCK 73 Rear Axle; Spicer 44, 3.73 ratio J-SERIES TRUCK 74-79 Front Axle; J10, 3.54 ratio J-SERIES TRUCK 74-79 Rear Axle; J10, 3.54 ratio J-SERIES TRUCK 74-86 Front Axle; J20, 3.73 ratio J-SERIES TRUCK 80-86 Front Axle; J10 J-SERIES TRUCK 86 Rear Axle; J10, 10 bolt cover J-SERIES TRUCK 87-88 Front Axle J-SERIES TRUCK 87-88 Rear Axle; J10 JEEPSTER 67-70 Rear Axle; Spicer 44, 3.31 ratio JEEPSTER 71 Rear Axle; 6 cyl., 3.31 and 3.73 ratios JEEPSTER 72 Rear Axle; 3.31 and 3.73 ratios JEEPSTER 73 Rear Axle; 3.73 ratio RAMCHARGER 74-78 front axle, 3.23 and 3.54 ratios RAMCHARGER 79 front axle RAMCHARGER 80-84 4x4, front axle SCOUT 68 Rear Axle; 26 spline pinion (late), 3.73 ratio SCOUT 69-80 Rear Axle; 2.72 thru 3.73 ratios SCOUT 72-75 Front Axle; Spicer 44, 3.07 thru 3.73 ratios SCOUT 76-80 Front Axle; 3.07 thru 3.73 ratios SUBURBAN 65-66 1000 Series; 4x2, Spicer 44, 3.07, 3.73 and 3.54 ratios SUBURBAN 65-66 1000 Series; 4x4 (front & rear axle) SUBURBAN 65-67 10 Series; 4x2, 10 bolt cover SUBURBAN 65-72 10 Series; 4x4, front axle SUBURBAN 67 1500 Series; 4x2, 10 bolt cover, Spicer 44, 3.07, 3.73 and 3.54 ratios SUBURBAN 67-68 1500 Series; 4x4, rear axle, 10 bolt cover SUBURBAN 67-72 1500 Series; 4x4, front axle SUBURBAN 68 10 Series; 4x2, 10 bolt cover, Spicer 44 SUBURBAN 68 1500 Series; 4x2, 10 bolt cover, Spicer 44, 3/8" bolt, 3.07, 3.73 and 3.54 ratios SUBURBAN 69-70 20 Series; 4x4, front axle, 3.07, 3.73 and 3.54 SUBURBAN 71-72 2500 Series; 4x4, front axle, 3.07, 3.54 and 3.73 ratios SUBURBAN 73-76 10 Series; 4x4, front axle, 3.07 and 3.73 ratios SUBURBAN 73-77 1500 Series; 4x4, front axle, 3.07 and 3.73 ratios SUBURBAN 77-80 10 Series; 4x4, front axle, Spicer, 2.76 thru 3.73 ratios SUBURBAN 78-80 1500 Series; 4x4, front axle, Spicer, 2.76 thru 3.73 ratios SUBURBAN 78-80 20 Series; 4x4, front axle, Spicer, 2.76 thru 3.73 ratios SUBURBAN 78-80 2500 Series; 4x4, front axle, Spicer, 2.76 thru 3.73 ratios TRAIL DUSTER 74-78 front axle, 3.23 and 3.54 ratios TRAIL DUSTER 79 front axle TRAIL DUSTER 80-81 4x4, front axle WAGONEER 62-71 Rear Axle; 3.73 ratio WAGONEER 72-73 Rear Axle; exc. 4.27 ratio WAGONEER 74-78 Rear Axle; 3.07 and 3.54 ratios WAGONEER 74-79 Front Axle; 3.07 and 3.54 ratios WAGONEER 79 Rear Axle; 3.54 ratio WAGONEER 80-83 Front Axle WAGONEER 87-90 Rear Axle; Spicer 44 Spicer 44 axle. 26 spline pinion. |A| & |B| interchange by including differential case. A ----------- C6TZ4209AJ 41-11 (3.73) $155 obs 15582886 41-11 (3.73) $292 obs 351817C91 IHC, 41-11 (3.73) $120 41-11 (3.73) $475 Dodge, 41-12 (3.42) 41-12 (3.42) 41-12 (3.42) Dodge, 42-13 (3.23) $420 obs D7TZ4209C 42-13 (3.23) $324 obs 15579210 42-13 (3.23) $303 obs C6TZ4209D 43-13 (3.31) $126 obs 351815C91 IHC, 43-13 (3.31) $118 43-13 (3.31) $685 D7TZ4209B 43-14 (3.07) $408 obs 15584140 43-14 (3.07) $315 obs 389310C91 IHC, 43-14 (3.07) $119 43-14 (3.07) $435 Dodge, 43-15 (2.87) 43-15 (2.87) 43-15 (2.87) IHC, 43-15 (2.87) 43-15 (2.87) Dodge, 46-13 (3.54) $510 D7TZ4209D 46-13 (3.54) $407 2428707 46-13 (3.54) $272 obs 351816C91 IHC, 46-13 (3.54) $124 46-13 (3.54) $420 obs 47-16 (2.94) $370 obs D7TZ4209A 49-18 (2.72) $392 obs 574120C91 IHC, 49-18 (2.72) 49-18 (2.72) $575 Ident: 18426 R43 Ident: 18437 R46 Ident: 18515 R41 Ident: 30060 R43 Ident: 31492 P14 Ident: 32072 P11 Ident: 32171 P13 Ident: 32830 P13 Ident: 37244 P13 Ident: 37245 R42 Ident: 37791 P15 Ident: 37792 R43 Ident: 38633 P18 Ident: 38634 R49 Standard cut spiral bevel.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
03-20-2002, 02:27 PM | #6 |
JJR I have a simalar problem as jjg. A 68 GMC 3/4 4x4 with very low gearing. Can you help me identify the front and rear differentials.
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
03-20-2002, 02:32 PM | #7 |
I didn't think they put a 44 in the back. Guess I was wrong.
As for the '68 3/4 ton 4X4, It probably has the following: Dana 44 closed-knuckle front, Corporate 10-bolt (H-052 or H-072) rear with 4.57 gears. At least that's going on what I have in my '68 . ------------------ Bowen '68 K20 fleet '69 K10 swb fleet '72 C10 lwb step
03-20-2002, 04:12 PM | #8 |
Erl, according to Hollanders you front is a Dana 44 and your rear could be a Dana 60 or Corporate chevy. If the carrier is non- removable it is a Dana 60.
03-20-2002, 04:21 PM | #9 |
3.07 dana60 is his rear axle
dana44 were used in gmc trucks alot especially in 67 all 67-72 4x4 used dana44 fronts only, no matter series of truck, no dana60 til after 72 in front all dana 44 and 60 are 10 bolt eaton 3/4 ton and 1 ton axles are 10 bolt also ckhd is correct and JJR has the listings and erl your front wil be a dana44 with 4.55 and either rear with 4.57, sometimes there was 4.56 ratio rear, probably is the dana60 ratio i bet, i owuld have to look. front and rear ratios did not match on purpose, thats what they did from factory |
03-20-2002, 04:57 PM | #10 |
Can you tell me what the 3.07 means in front of the Dana60? Does anyone know why the gear ratios were different on the front and back of a 4x4?
03-20-2002, 05:20 PM | #11 |
THANKS guys for everyone that helped me out here, so my next question is how do the DANA 44 rate, are they a good rearend???? anything i should watch out for?
thanks again John |
03-20-2002, 05:35 PM | #12 |
well 3.07 is the ratio, the driveshaft turns 3.07 times per revolution of the ring gear, IE axle shaft
dana44 has larger pinion gear stub diameter than our 12 bolt axle,s and also keep in mind that 3.07 and 3.54 and 3.40 gearsets are stronger than say 3.73 , 4.10 , 4.11, 4.57, etc i wont get into details yet, unless i have to,. i wouldnt worry about the 44 coming apart, the shafts are stronger than the earleir versions are, and other series of dana axles cept the dana 60 ones, which are 30 and 35 spline, 44 are 30, most of them anyways, the later ones like ours ------------------ -71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it- -'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies -79 G20 pass van, 350/th350/10bolt, paint is overrated Randy- Lincoln, IL randy@ccaonline.com © RSS Enterprises 2000 [This message has been edited by Fast68Chevy (edited March 20, 2002).] |
03-20-2002, 05:56 PM | #13 |
The 43-14 refers to the number of teeth on the ring gear and pinion respectively giving a ratio of 3.07 and a fraction.
04-05-2017, 07:07 PM | #14 |
rusty 66
Re: HELP ME DECODE WHAT KIND OF REAREND I HAVE.
Hi I have a rear end that has
5 20 73 Dana 18737 a3d10 46 13 I think it came out of a 62 chevy 1/2 truck how can I tell what the gear are Posted via Mobile Device |
04-05-2017, 09:33 PM | #15 |
46 divided by 13 !! You have 3,54 gears.
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
04-06-2017, 01:42 AM | #16 |
rusty 66
04-06-2017, 08:07 AM | #17 |
04-06-2017, 11:48 PM | #18 |
rusty 66
