12-30-2013, 04:59 PM | #1 |
PARTING OUT 1968 CHEVY 327 ENGINE 3914678 VO605YV n.e arkansas.
parting out this 1968 chevy 327 engine. NO heads or exhaust maniflolds. has forged steel crank standard bore short block. crank is loose like it has a loose rod. and has been turned $300.00 picked up here the casting number is 3914678 the suffix code on the front is VO605YV .
12-30-2013, 05:02 PM | #2 |
Re: PARTING OUT 1968 CHEVY 327 ENGINE 3914678 VO605YV n.e arkansas.
more of engine.
12-30-2013, 05:03 PM | #3 |
more.
12-30-2013, 05:10 PM | #4 |
Intake air cleaner availlable?
12-30-2013, 05:12 PM | #5 |
12-30-2013, 05:34 PM | #6 |
1968 Q JET intake. with oil spout casting number #3919803 $85.00 plus shipping.
12-31-2013, 10:48 AM | #7 |
Are you selling the oil pan?
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
12-31-2013, 11:28 AM | #8 |
yes $50.00 plus the freight looks good no dents.
12-31-2013, 12:52 PM | #9 |
I'll take the oil pan thanks
12-31-2013, 03:04 PM | #10 |
Are accessories brackets availlable
12-31-2013, 04:17 PM | #11 |
it only had the power steering pump,crank pulleys and the water pump pulley. $125.00 for the power steering pump. $75.00 for the pulleys. plus freight.
12-31-2013, 04:19 PM | #12 |
engine fan is $60.00 plus freight.
12-31-2013, 05:47 PM | #13 |
Is the fan the same as a '67? Could you check freight for the fan and oil pan for 68803? Thanks.
12-31-2013, 05:49 PM | #14 |
I would be interested in the pulleys also if 530FF passes.
01-01-2014, 11:47 PM | #15 |
I'll take the pulleys shipped to 92020
Oil filter canister and timing belt cover availlable? Thanks |
