12-31-2013, 06:56 PM | #1 |
Poor man's '63 aluminum grill
As most us know, aluminum grills are hard to find. We mostly see 64-66 if any. I have been on lookout for months for a '63 grill, no dice. Then some of you are fortunate to grow 'em on trees (Rene C/10 King).
While cleaning out the garage, I noticed too many spray cans. Why not put 'em to use. Started with the basic tools for removal, die grinder, 4 in. grinder, wire wheels, and some spray cans. Now we all know there is no such thing as chrome paint, so I renamed it 60-66 C-10 Anodized Grill Paint. This is before removing anything on my Panel. You can't really tell on these pics but the white paint was really on there. Somebody went paint brush crazy on it. Another angle. The screws on the trim rings were in really bad shape. I'm sorry I skipped a pic, but I removed the complete grill with lights and all because the trim rings would not come out. Once it was out, I ground out the rivet fasteners to get to the trim ring screws. Besides it gives access to paint the headlight brackets.
"El Jerry" '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
12-31-2013, 07:15 PM | #2 |
Re: Poor man's '63 aluminum grill
Now here are the headlight brackets. This gives me time to replace bad screws. I used a wire brush and a Scothbrite scuff pad since I don't have a bead blaster. I also get to primer paint. I used a flat black to match up the patina.
A light scuff with the pad and a light primer will do. Since the grinders won't fit, I also scuffed the back of the grill. I did half of the paint removal here. This is where the die grinder helps. It'll get in through tight spots with the wire wheel bit.
12-31-2013, 07:34 PM | #3 |
Here is the grill with the paint removed. One thing I don't recommend is using paint remover. Wire wheels and paint remover do not mix, you'll get it all over.
Here I can take a grinder break and paint the body with a flat black. Another angle. Two coats of this flat black from a dollar store does the job. While the body dries, I continued on the brackets. Like I mentioned earlier, a scuff pad helps. Rust dust gets all over.
12-31-2013, 07:48 PM | #4 |
Now I tape up the rest of the body for the white.
Here's the first coat. On this I used a white primer for paint. Simply because the dam can was in my way. I didn't want that glossy look either. Looking better without the tape. Hood closed looks even better. Another angle. All that headlight wiring was already brittle, so I replaced it and rerouted for a cleaner look.
12-31-2013, 07:54 PM | #5 |
looking good.
I love that way of deciding paint color. The can was in my way |
12-31-2013, 07:57 PM | #6 |
Now it's time to overspray the neighbors.
Can't forget the trim rings. First light coat. Those are done. After the second coat. Here you can coat the back of all pieces.
12-31-2013, 08:17 PM | #7 |
I forgot to mention earlier but when I assembled the headlight brackets to the grill, I simply got some small screws with nuts to replace the rivets. These clips are for the trim rings. Now....why does Harbor Freights have to sell me a whole box? I just need 6.
And here it is assembled together. Front view. And the other side view. Pretty damm close if you ask me,.....at least at 55 mph passing by. And that's how save time and money looking for an aluminum grill.
12-31-2013, 07:48 PM | #8 |
So far , so good!
GOD BLESS AMERICA! |
12-31-2013, 08:09 PM | #9 |
But Found Her 25yrs Later!
That is looking really good.
12-31-2013, 08:18 PM | #10 |
Man that does look good ! Really needed the detail behind the grille to, looks great !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
12-31-2013, 08:19 PM | #11 |
That looks pretty damn good! I never have liked chrome paint but that came out great
12-31-2013, 08:24 PM | #12 |
NICE! It's ultra rare magnetic aluminum.
12-31-2013, 09:00 PM | #13 |
When I was growing UP, we called that paint "DUTCH CHROME" but I think it turned out pretty good and it's a improvement over what you started with.
12-31-2013, 09:04 PM | #14 |
Yep might have to borrow this but all the credit will be yours my friend... Great job!!
May your life be like a roll of toilet paper... Long and useful or short and crappy!!! http://67-72chevytrucks.com/vboard/s...d.php?t=584520 |
12-31-2013, 09:49 PM | #15 |
that is astoundingly great!
12-31-2013, 09:58 PM | #16 |
very nice job!
12-31-2013, 09:59 PM | #17 |
Nice job. I dont think a guy on here hasn't at one time or another tried their hand at chrome paint... I just gotta ask..
how come they just dont sell the paint they colored the spray paint can lid!? Haha
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 |
12-31-2013, 10:17 PM | #18 |
Wow, what a makeover! The coolest part is that it took very little money (but a lot of labor) and the results are outstanding. Nice job!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
01-01-2014, 02:37 AM | #19 |
Chingon
01-01-2014, 10:45 AM | #20 | |||||||
thank you thank you Quote:
thank you bro, ese, I was bored thanks, yeah might as well Quote:
thank you Capt thank you carnal
01-01-2014, 01:00 PM | #21 |
Having just read this, I love your ingenuity.
Great result.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
01-01-2014, 01:49 PM | #22 |
Check The Champ, Demonstrator
Absolutely Gorgeous!
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
01-01-2014, 09:04 PM | #23 |
wow, thanks Grizz
thanks aero, coming from you
01-02-2014, 01:27 AM | #24 |
It looks awesome!! Thanks for sharing.
01-02-2014, 07:31 AM | #25 |
The color turned out really good. What was the color under the silver then?
