04-24-2014, 09:12 PM | #1 |
Operation Rustbucket
Here is the 89 K1500 Silverado stepside 4x4 I just purchased as my new project. It has a 5.7. I paid $500 for it. This is as bought.
04-24-2014, 09:18 PM | #2 |
Re: Operation Rustbucket
First thing I have done is replace the following
Spark plugs, spark plug wires, rotor, distributor cap, radiator cap, tensioner, tensioner brace, serpentine belt, fuel filter, air cleaner and filter, IAC. I also changed the oil and filter, coolant and rear differential service. Up next will be the transfer case, front diff and tranny service. It already had a new radiator, alternator and battery |
04-24-2014, 09:21 PM | #3 |
I then scrubbed and deodorized the interior.
Going to replace the fenders and doors as well as new cab corners and rockers. Floor is solid. Then a repaint |
04-26-2014, 11:55 PM | #4 |
Nice project!!! Boy I never knew for them to rust that high up on the door. Can't wait to see what you do next with her! An only $500!!!
04-27-2014, 12:05 AM | #5 |
They had those stainless steel panels on the truck and I think that is what started the rust they are still in holding the bottom of the doors together
04-27-2014, 04:46 PM | #6 |
Replaced the throttle position sensor and what a difference that made.
05-03-2014, 10:19 PM | #7 |
New front rotors, pads, caliper and hose.
Before After Also added new 17 in tires and rims |
05-11-2014, 04:53 PM | #8 |
Adjusted the shift indicator cable and then replaced the actuator and repaired some wiring and the 4x4 is working. Also decided to drop in a L98 5.7L out of a 88 GTA I rebuilt for a future project and this is it.
05-11-2014, 05:04 PM | #9 |
Even with the rust it looks like a good deal from here ,congrats .
05-21-2014, 09:35 PM | #10 |
Removed the fenders and hood, in preparation for the engine removal and installation of the 5.7L L98 TPI .
[IMG]http://img.photobucket.com/albums/v345/Ogstad/imagejpg1_zpse701e70a.jpg[/IMG |
06-11-2014, 10:25 PM | #11 |
Anymore on this truck?
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
