4 inch lift pics 67- 72 k30's
Ok guys looking to lift my new project need some refrance pics! I would like to see 67-72 k20's with 4" lift and 35/315's with a refrance to the hight of the truck next to it. Thanks for the help guys!
Re: 4 inch lift pics 67- 72 k30's
My 72 k20 31575r16
4inch rough country suspension kit
.................._____ __________//___{\____ /__---____//____/__---/ .....(O). ..................(O). BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4 ![]() |
Better distance pic
Brian |
Yep shes a 4x4
Man nice truck!!!! I am assuming that is a 8' fence behind it.
yep!
How did you set up the rear? Springs, shackle flip or block how is the ride?
Heres a good pic of the rear set up
Looks nice! What is the offset on your wheels any finder rub issues?
thanks, 4 inch off set, no fender rub
The wheels are 16 inch eagle alloys ![]()
So I would assume you did all the work you self if I could figure out how to download pics to this sight I would show you mine Pretty sweet story raely got the truck for 200 from a old farmer I know the original coil lead burned due to a bad regulator so a shoddy mechanic they had work on it wired it for a electronic ignition so naturally it would burn the points within minutes got it home put a hei distributer in it and fired right up!!!! Any way how hard is it to fix the rocker floor pan rust that is typical to these trucks? I am a good welder fab guy but not much experience doing body work?
#15 |
Gentlemen, I am building a 72 GMC quad cab 4x4 on a one ton longhorn frame. 6" suspension lift on dana 60 rears and 44 fronts with 4:11's. I am putting 315/75R16's under and want ball joints that wont submit to heavy tire wight and hard core days in the field..
Any recomends?? Ive been looking at Spicer and Proforged |
#16 |
Well first thing first if you have a ball joint 60 the least of your worries will be ball joints the spring mount pads are way wider than your long horn frame!!! If you are using a 44 dynatrac offers a Re-buildable ball joint!
#17 |
Yeah.. There is a lot of modifications to relocate mounts.. It's a 44 front axle.. I will look into those.. Thanks!
#18 |
A quad cab was this ever offered factory or are you grafting two cabs together?
#19 |
Graft and stretch job... building it for extreme duty. I'm wanting ball joint an tie rods to handle the tire size and off road challenges..
#20 |
If there is an American made extreme duty B joint available, I will spend the $.i don't want to rebuild the front end in 30k miles..
#21 |
I think I would go with a 14 bolt rear and if you have the $$$ to spend build a customs 14 bolt for the front using crane hd king pin 60 nuckles watched a episode of xtreme 4x4 were they bult one pretty sweet! They make a kit crane xtreme14 look it up! Then you would have a cool custom axle to go with a cool custom truck!!!!
