Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 03-18-2015, 03:50 PM   #1
68c10airstream
68c10airstream's Avatar
homemade tank cart using spare tires
I made my tank cart using space saving spare tires from front wheel drive gm cars. I would use the rear wheel bearing assemblies and the spare tires from the same cars. I welded a plate on each end of a cross tube for the wheel bearings to attach to. I purchased hand rail tubing and pre-made 45/90 degree fittings to weld together for the handle. The deck for the tanks has a angle iron front ledge on it for the rest foot up front. The handle goes down through the cross tube and stops at the floor area. The bottom of the handle and the angle iron front create a 3 point plane for the cart to rest on in the upright position. I used freeze plugs on the bottom of the handle tubes to fit snug enough to be tapped in place with a hammer. This allowed me to make a final level adjustment and tack weld them in place. I attached a ammunition box to hold all of the tips, goggles, tip cleaner,etc, because i got tired of dusting everything off every time i needed to use it. The ammo box has a water tight rubber seal on the lid and id cheaply priced. The advantages of this design are this; heavy duty, rolls over anything very easy (air hoses, tools, 2x4's etc) make it fit just what i have, nothing else, last forever, fairly cheap to make. I should add that when this is in the upright position the wheels are just off the floor. I got lucky taking the handles through the cross tube as this creates a cart that is nose heavy. Olny problem is if you remove both tanks with everything on the cart, hoses, torch head, etc, the cart will flop back to the floor. Just change one tank at a time and all is well.http://67-72chevytrucks.com/vboard/p...ictureid=21105
68c10airstream is offline   Reply With Quote
Old 03-18-2015, 03:53 PM   #2
68c10airstream
Re: homemade tank cart using spare tires
another pic
Old 03-18-2015, 03:56 PM   #3
68c10airstream
side view
Old 03-20-2015, 10:34 PM   #4
68c10airstream
Thanks for the nice comments. The pics make the tires looked like they are way off, but it must be the camera lens. I positioned the wheel bearings so it gave a slight toe-in and slight negative camber (i actually measured). Outside measurement from one wheel to the other is 30 1/2". I work at a power plant and will move a contractor's big steel wheeled cart around and they work ok, but are noisy and huge to accomidate various sizes of tanks. The hoses don't flop around and i added a hook to hang the torch head on. I'm going to weld on a hanging loop so after i'm dead the next owner can use my chain fall to pick it up and put in his truck. Then the new owner can tell my wife and/or kids "he thought of everything"
Old 03-18-2015, 04:36 PM   #5
72bowtiestepper
Nice Job ! I like the ammo box idea for torch tip & other tool storage also.
72bowtiestepper is offline   Reply With Quote
Old 03-19-2015, 09:25 PM   #6
earl84
Very nice.
earl84 is offline   Reply With Quote
Old 03-24-2015, 08:01 AM   #7
bbcmudtruck
Love it! Truly an all terrain cart! I have an old and very large/heavy duty cart and would love to have those tires. Only issue I could think of is getting a flat haha.
bbcmudtruck is offline   Reply With Quote
Old 03-30-2015, 09:38 PM   #8
swamp rat
swamp rat's Avatar
Nice idea!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-11-2015, 09:35 PM   #9
Cape Codder
Cape Codder's Avatar
Very nice, you can't beat the large diameter tires when moving over any uneven surface.
Cape Codder is offline   Reply With Quote
