06-09-2015, 01:43 PM | #1 |
"Best Way" Spring Hanger Mounting?
Not sure if this has been covered before but we need to hang our D60 & 14 Bolt DRW axles on my Longhorn 4x conversion project and could use some advice on the best way to do this. We’re replacing all the spring hangers and punching all new holes as none currently line up.
Originally we planned to weld up any holes that partially lined up and then re-drill and bolt them on with 3/8” grade 8 frame bolts. Found that most all the hangers original rivet holes have a little larger opening than that, new plan is to punch everything over to 7/16”. A friend suggested we just weld um on and forget about it? My question being is welding any of this a good idea or would some flanged frame bolts with self-locking steel flange nuts & Loctite Red be enough? Seems like some hanger to frame weld might help them from egging out the frame holes or is this overkill?
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
06-09-2015, 03:07 PM | #2 |
Re: "Best Way" Spring Hanger Mounting?
Using the frame holes as a template I would drill out the bracket than the frame rail. The factory holes are on the edge of 10mm in size. I've always gone to 7/16 fine thread gr. 8 with grade 8 flats and a locking nut such as either a pinch or flange lock, then torqued them down to 70 lbs. I even did an experiment one time with just a regular nut torqued to 70. After 20 years it never came loose
06-09-2015, 08:51 PM | #3 |
Modifying the bracket rather than the frame when possible makes good sense.
Was the regular nut used with a lock washer or anything else like a threadlocker?
06-09-2015, 11:23 PM | #4 |
You may not be able to redrill the upper holes in your bracket to match the frame. It appears the upper holes in the frame are to high for the bracket. It looks like the bracket is not flat where the upper holes in the frame are.
The nuts you want to use are lock nuts. They do not require a lock washer or thread locker and will not back off on their own.
68 4wd Stepside 69 2wd Stepside Project 71 2wd Blazer Project 72 2wd 3/4 Ton Project or Parts? 73 4wd Blazer |
06-09-2015, 11:35 PM | #5 | |
No it wasn't, just a flat washer and my snap-on torque wrench set at 70. These were holding in a dropped front x-member that I fabricated to convert a 2wd frame to 4x. Somebody now owns the truck up in Washington state |
06-10-2015, 10:13 AM | #6 | |
Wow, you would have thought that would have backed off by now if it was going to. I'd think the fine thread helps it to stay put also.
06-10-2015, 11:19 AM | #7 | |
Simple? What's simple?
I used all flange-headed gr.8 bolts with self locking (Keps is the name) nuts. GM actually specs those in the service literature for rivet replacement (I have a reference somewhere), and you'll find them used in the square body frames where cross members and things are bolted in.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
