03-26-2016, 09:42 PM | #1 |
Striaght six 230
I need some opinions i found a striaght six 230 for 100$ the guy said it was running but he just put in a fresh rebuild engine in his truck and didnt need it but my question is is it worth 100$ how hard would it be to put it in a 1971 c10 that had a 350 by the way its toast an well a 3-speed TH350 or a TH200 automatic transmission bolt up to the 230 engine transmission is out of a 83 oldsmobile delta 88 any help at all please thanks
03-26-2016, 10:14 PM | #2 | |
Re: Striaght six 230
03-26-2016, 10:15 PM | #3 |
See if he'll let you take some time doing a compression test. If it comes with all accessories, and cylinders all check out, go for it. It should be a direct bolt in, same bellhousing bolt pattern, but you will have to get some a/t brackets if they don't come with the six deal
03-26-2016, 10:21 PM | #4 | |
03-26-2016, 10:26 PM | #5 |
A/T, "automatic transmission". It's a question, theirs no dumb here. That's what forums are about
03-26-2016, 10:34 PM | #6 |
03-27-2016, 12:02 AM | #7 |
03-27-2016, 12:21 AM | #8 |
03-26-2016, 10:38 PM | #9 |
You would have to measure your transmissions to answer that one
03-26-2016, 10:41 PM | #10 |
A short tail TH350 will match the manual 3spd length more or less. The driveshaft will take up any in or out slack
03-26-2016, 10:44 PM | #11 |
