Old 04-19-2016, 10:19 AM   #1
turbotruck
Cpp "bent" trac bar
I have the cpp "bent bar. truck is lowered with 3' drop springs and a 1" block
when installed the bar does not sit level as the stock bar does. does it matter?
It is a street strip truck. the drive-shaft occasionally rubs on the cross-member.(i'm guessing when launching) and is more to the right and not on center with the stock bar. so i'm guessing i need the adjustable one. anyone have any insight to this?
turbotruck is offline   Reply With Quote
Old 04-20-2016, 09:34 AM   #2
turbotruck
Re: Cpp "bent" trac bar
bump
Old 04-20-2016, 10:23 AM   #3
panhandler62
Java Mechanic
panhandler62's Avatar
The track bar does center the rear end so you may need to adjustable bar to get set up correctly at ride height.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 04-20-2016, 10:49 AM   #4
turbotruck
if i use the panhard bar. i can center the rear end, but the cpp bar. does not sit level when installed
Old 04-21-2016, 10:18 AM   #5
turbotruck
bump
Old 04-21-2016, 12:38 PM   #6
bsampson
You might try posting pics of the bar installed at ride height, and if you get some measurements of how much clearance there is on each side of the driveshaft to the crossmember.
With the longer tracking bars (like what you have), the arc is less than it would be with the shorter factory panhard bar. This would create less lateral movement when you hammer down and the rear end squats. So this is a step in the right direction.
The cpp tracking bar is probably not level by design, and I wouldn't expect it to be a problem. If the driveshaft isn't centered, and it is rubbing, than an adjustable bar could fix that.
There are other brands of tracking bar systems that lower the mounting point further below the frame, probably for the purpose of keeping the bar more level, and minimize that lateral movement.
bsampson is offline   Reply With Quote
Old 04-25-2016, 02:09 PM   #7
turbotruck
i reinstalled it. its not too bad. except the bar isnt short enough to center the axle. its off 1/4'
