Where to tie in on a good electrical point (underdash) for newer Chevy P/U?
Try to make a long story short. Will be adding a GPS system that needs 12 Volts to
go on when engine runs;off when engine shuts off. GPS system will augment my OnStar. My application is a 2014 Silverado. Where is a good/simple point to tie in and get this voltage? We all know with the older vehicles it was as simple as running a wire to the open fuse box. How about these new vehicles? Thanks in advance-Larry P.S. Wonder is GM give some extra electrical points for this. (GPS's-CB's and etc) |
Re: Where to tie in on a good electrical point (underdash) for newer Chevy P/U?
Between my owners manual (2014 Silverado) and the internet I have found the proper fuse
in the front side panel fuse box. (By drivers door) I will use CarQuest#ST231 fuse taps to tie into the fuse. Hope it works. Thanks. Larry ![]() |
