Old 11-01-2017, 10:23 AM   #1
bigboar
Started build on a 66’ (Photo Heavy)
Hey all,
Long time lurker, first time poster. I have started a build on a 66 3/4 ton which belonged to a friends dad. We worked out a deal on it and its going to be for my son who is 14. The truck has 41k miles on it with a 3 on the tree and the 305 big block v6 long bed.
The plan for the truck is to bag it, add power steering, 4 wheel disc brakes, do a custom interior and leave the outside old. I have had the truck a few months now and made some progress.
We started with a 1985 donor which i did the crossmember swap and used the rear end out of. I bought an adjustable trailing arm crossmember and got a set of the nascar arms for pretty cheap. I then built a panhard bar and did a rear the rear disc conversion using eldorado calipers so he would still have an e-brake.
The next step was installing the bag kit. It uses a bluetooth module and i used an iphone 5 i had lying around which is what will be controlling it.
I then moved on to the power steering situation. Not fun, couldnt find any pulleys or brackets so I ended up modifyi g the stock pulleys along with using the crank pulley and pump from the 85 donor. I had alot of help from the previous owner who happens to own a machine shop. We split the crank pulley and he machined and welded them to my existing crank and water pump pulley. He then helped me make the pump bracket. I then welded in one of the steering box brackets and shortened the stock steering shaft and used the box from the 85 which looked like it had recently been replaced and is the 3.5 ratio. It is all in and works perfect, it is nice to have power steering! The brakes were simple as i bought the kit with master, booster, and disc proportioning valve and ran new lines using the copper nickel line. That stuff is great to work with!
The interior is where i am at now and it is a work in progress. It is going to be pearl white. I bought one of those intellitronix digital dash kits for a c-10 and went to work on that. I like how it turned out. I just completed the console build. Ended up with over 50 hours in it. I even went through the trouble of making ductwork run through it so the heat will blow on the driver side😂.
I could go on and on but this post would take forever so here are some pics of it so far. Bare with me....
bigboar is offline   Reply With Quote
Old 11-01-2017, 10:32 AM   #2
bigboar
Re: Started build on a 66’ (Photo Heavy)
more...
Old 11-01-2017, 10:34 AM   #3
bigboar
more photos...
Old 11-01-2017, 10:36 AM   #4
bigboar
and some more pics....
Old 11-01-2017, 10:38 AM   #5
bigboar
adding more photos
Old 11-01-2017, 10:41 AM   #6
bigboar
power steering and heading toward inerior
Old 11-01-2017, 10:54 AM   #7
bigboar
this is it. I promise also, not sure why but some photos are sideways or upside down. for instance, the door panels have the flames at the top.
Old 11-01-2017, 11:01 AM   #8
okndn
I am liking where you are going with the build
okndn is offline   Reply With Quote
Old 11-01-2017, 11:02 AM   #9
bigboar
Thanks!
Old 11-01-2017, 11:30 PM   #10
Captainfab
60-66 Nut
Nice work
Old 11-02-2017, 08:49 AM   #11
bigboar
Originally Posted by Captainfab View Post
Nice work
Thank you! Its your power steering plate I used.
Old 11-02-2017, 08:08 PM   #12
bigboar
a little more accomplished.. i bought billet knobs for the headlight,choke and wiper switches and redrilled them to fit. i also made the mount for 4” speakers in the dash(not to worried about looks with it since its hidden). Made the lower panels for the doors which will hold the 6x9s. The panels will be cover with black vinyl like the seat only I am having my shop name embroidered in them in between the speakers.
I also got everything removed from the inside and am ready to start the bodywork and get it ready to refinish.
Old 08-02-2018, 01:39 PM   #13
66C10LB
Like the custom focus. It is going to be unique!
66C10LB is offline   Reply With Quote
Old 08-02-2018, 06:06 PM   #14
bigboar
Thanks! been a long time since I posted anything and it is now almost complete.
Old 08-02-2018, 01:48 PM   #15
okndn
If you have time could you get into a little more detail on the console and the door speaker mounts. Basically anything interior
Old 08-02-2018, 06:07 PM   #16
bigboar
sure. what exactly are you looking for? I made the console and lower speaker mounts out of mdf.
Old 08-02-2018, 06:15 PM   #17
bigboar
Going to catch up on photos.
Old 08-02-2018, 06:32 PM   #18
bigboar
more interior...
Old 08-02-2018, 06:36 PM   #19
bigboar
finishing up interior...
