12-03-2020, 09:31 PM | #1 |
A plan to make my '70 pretty(er)
Hi all,
I've been reading so much great information on this forum. Thank you to all that take the time to impart their wisdom. In my reading it became apparent that I needed a plan before I start painting this beast so I thought I'd lay it out here so you all can tell me what I'm missing and where my plan could be better. The truck is running and driving and I'm going to miss cruising around in it, but she's loud inside the cab and the rest of the family doesn't love it so much! The plan is to put together a driver that I can still throw crap into the back of with out having a coronary. I want it to look nice, but not that nice, and make it comfortable for the family to ride around in. Here's how she stands: Can we get some long bed love?! It's a truck - more is more! What I know I need to do: + remove the really crappy paint that is chalking off. My plan is to sand with 80 grit on the DA. Do I really need to go to bare metal or can I get away with leaving whatever is good from the original paint? + cab corners, rockers, inside roof on passenger side by windshield, and the driver's bed side all need to be replaced Not a good fix! Even more reason to replace the left bed side + Something has to be done around my drip rails in places. Is there a "pretty good" fix for this or am I in for a big job? + Giant dent in the passenger door from the hinge stop failing + Lots of holes in the floor and dash from various farm type "add ons" to be patched + Pretty big ding on the roof that needs to be pulled out. I'm planning to work piece by piece starting with the hood which is in pretty good shape and move towards the parts that need more work once I have some sea legs. I'll disassemble, sand it down, do the body work and epoxy primer it. Then on to the fenders, doors, bed, and cab. I'll also get some paint on the frame while it's apart - what's a good choice for that? Once all the pieces are ready I'm planning to reassemble and fit everything. Then I'll move it in the garage with the bed pulled back a bit and hit it with a couple of coats of high fill primer, block it, and paint it with BC/CC(or SS? seems to be some debate here over which is better for someone with VERY little painting experience) in a non-metallic light gray. Originally I was thinking of using some really cheap paint and I could probably still be talked back into that, but after much reading it seems like the general wisdom is to use something along the lines of PPG Omni. I am still very tempted by the reasonable pricing of Summit's paints though. Input please! I guess that's about the size of it. What am I missing? I'd like to get this done in a reasonable time frame (duh) but not rush it and seeing how we're going to be at home a bit more now here in California I'm thinking I could get a fair amount done in the next couple of months. |
12-03-2020, 11:10 PM | #2 |
Re: A plan to make my '70 pretty(er)
Some of that would be easier to replace vs repair.
I saw this on CL earlier today, looks like there are (some) decent parts and it's only about an hour away from you... https://sandiego.craigslist.org/nsd/...227910841.html Anyway, I look forward to seeing your progress on this! Best of luck!
-Tim '65 GMC that identifies as a Chevrolet |
12-04-2020, 07:05 PM | #3 | |
I hope so. I've done some welding and watched a lot of videos! |
12-04-2020, 06:46 PM | #4 |
Will you be able to weld pieces in ?
12-04-2020, 06:49 PM | #5 |
Will you be able to weld pieces in?
12-04-2020, 11:05 PM | #6 |
Not trying to rain on your parade..but welding thin sheetmetal is a whole different animal...I'd suggest grabbing some old fenders from a body shop and practicing before you commit to welding on the truck..
Anywhere you can use a copper backer it will help prevent burn thru...
12-04-2020, 11:26 PM | #7 |
This is a great learning experience. Bodywork, you make a mistake, you do it over again until you're satisfied. There are a lot of great YouTube videos on body work and painting you can learn a lot from .
12-06-2020, 05:25 PM | #8 |
Anything can be fixed . Once you open up that cab your going to find a lot more rot. It's like an iceberg 90% is unseen. Practice on some fenders to get the welding down, do you have access to a mig or tig?
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
12-06-2020, 06:40 PM | #9 |
I can believe that. mig welder is what I have. I definitely plan on practicing on some old parts I have before getting into the truck itself. Thanks for the input everyone.
12-07-2020, 08:49 PM | #10 |
Use .24 wire low amps adjusting the feed to not burn thru. You using shielding gas or flux
12-09-2020, 12:28 AM | #11 | |
I have the auto darkening helmet and gloves. Didn't know about the 45 deg thing though. Definitely going to try that out. |
12-06-2020, 08:00 PM | #12 |
With restoration work you will always get some lumps, bumps, and bruises and a few burns. You know the old saying, Safety First .Well try to practice it as best you can
12-07-2020, 11:40 PM | #13 |
A good auto darkening helmet and a pair of gloves is a good investment. If you turn the torch on a 45 degree angle you'll be able to see a little better.
12-09-2020, 09:12 PM | #14 |
It looks like you're in pretty good shape. There are Coatings designed for marginally prepared surfaces. Permanent rust sealer[ aluminum pigmented] is used on Bridges and has a 20-year service life. Clean it up best you can make sure you put a second coat of the Permanent rust sealer on it and then any kind of black topcoat you'd like over it.
12-09-2020, 10:31 PM | #15 | |||
Yes my brother! Love me the long bed and you're right on about getting supplies in it. It's what a truck is for! Quote:
Thought of a few more questions: On the inside of these pieces should I use something like CLR to get as much rust out as possible? Seems like sanding in there is going to be...ah...challenging. Or should I just do like lupo said and use a rusty metal primer in there without doing much? Then once I have the insides cleaned up and primed I guess I'm going to top coat that with something other than my actual color for the rest of the truck. Maybe a low gloss black something? Suggestions? |
12-09-2020, 11:22 PM | #16 |
CLR is really lightweight stuff. Rust remover/ metal prep from restoration supply companies are much more aggressive and do the job much faster. When you get a good rust remover dump it down in all your welds. Cab corners , inside your doors , inside your rockers. A quality metal prep with zinc when you have your vehicle down to bare metal and you don't want to paint wipe a little rust remover prep on the panel and it'll stay rust-free for months in your shop.
12-10-2020, 12:48 AM | #17 | |
12-10-2020, 08:13 PM | #18 |
I discovered today that I can scrape the white paint off fairly easily with a scraper:
I'm guessing that means that I need to scrape it off because it didn't really adhere to the layer beneath. Or am I wrong and will the primer "glue" this down as long as I can sand it to look like this? I don't want to create more work for myself if I don't need to do this, but it seems like it probably needs to come off. I checked several places around the truck and it scrapes off easily everywhere. |
12-10-2020, 08:45 PM | #19 |
If it scrapes off easy, then it needs removed...get it down to goodly adhered paint or bare metal...my preference is bare metal...then get some epoxy primer on it
12-10-2020, 09:35 PM | #20 |
I agree to get the white off and as much as the green base paint as possible. I don't agree about using an epoxy primer over it. The reason being epoxy primer does 700 hours of salt spray urethane primers do 8000 hours salt spray ,better suited for a surface such as this one. Permanent rust sealer / surfacer are better suited for going over old paint and in some cases rusted surfaces because it deprives the surface of oxygen and moisture. After two coats of urethane sealer then comes the epoxy surfacer then the color coat. These vehicles done properly, you can drive for the next 30 Years. I did a 55 Chevy like this in 2006 and it's still show quality.
12-11-2020, 12:05 PM | #21 |
The white paint is flaky. Once you get that off you can evaluate the green, it seems to be holding up better to the scraps. probably won’t take too much longer to take it to bare metal if your using 60- 80 grit, especially on the flat panels. For door jams, drip rail, and fire wall I like to sand blast. You can get a 20-25 gallon blaster pretty cheap at harbor freight. Play sand from HD works well as a media if you strain the pebbles out. Keep the blaster away from larger flat panels like your hood because they can warp metal. If it’s thicker sheet metal like a cab floor support or has Intricate bends like door jams you can blast it, saves a lot of time rather than trying to sand in hard to reach areas.
12-11-2020, 06:43 PM | #22 | |
A lot of people say they sell it in the store for kids to play in so it must be safe . Sure it's safe in its unaltered state. But once you use it in a blaster you are cracking down the grains to powder that will stay on you and everything around you for a while. Ever look at the plume around guys using a blaster? To save 40 or 50 bucks isnt worth it . https://www.precisionfinishinginc.co...-a-sandblaster I use black beauty and grushed glass for blasting .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 12-11-2020 at 06:49 PM. |
12-11-2020, 08:34 PM | #23 |
This is what I use. https://www.amazon.com/Hobbyair-Supp.../dp/B003973Q9S
Yeah, always use appropriate PPE. We are talking about painting with dangerous chemicals, and don’t stick your tongue in that light socket. You can use sand as a blasting media people do it safely everyday. |
12-12-2020, 01:49 PM | #24 | |
No company that make blasters recommend sand as a medium. But enough on that subject
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 12-12-2020 at 01:55 PM. |
12-12-2020, 08:02 PM | #25 |
Thanks for all the good input guys. At this point I'm pausing to consider having it blasted professionally. I gotta weigh time vs $$, but it seems like a reasonable trade in this case. The white comes off but it's not quick. Once I've done that I still have to sand as much of the green off as I can and get the rust off the backs of the panels. That's a lot of time. After doing a lot of reading on these forums it sounds like the best approach for having it blasted is to take it in a bit at a time rather than blasting it all at once. That works for me, I'm not too far from a guy I've used before that has lots of experience blasting cars so I know he'll do it right. Like I said, I'm pausing to consider which makes the most sense for me.
