![]() Join Date: Aug 2001
Need speedo / gear help
I have a 79 K10 with 1/2 life 33 BFG AT KOs. 350/350/NP203. The 203 has been converted to part time and it has a 1:3000 ratio adapter on the speedo cable. The speedo reads little less than 10% fast (75 @ GPS 70). On the highway the odometer measures almost exactly 9 miles over 10 miles per mile markers. I have not pulled covers on the axles but I'm guessing they have been changed. My RPMs are about 2400 at GPS 70. I think they would be lower than this if the original 3.07 gears were in there. What gearing do you guys think I have? Is there another ratio adapter box that would get my speedo / odo more accurate?
79 K10 77 MGB 79 Kawasaki KZ1000 |
All about them K’s
![]() Join Date: Jun 2014
Re: Need speedo / gear help
Well, using the calculator below, it looks like with 3:07s you’d be running approximately 76-77 mph at 2400 thru 1:1 high gear.
With 3:42’s you’d be closer to 69-70. This is all estimations though because the actual tire size is going to change the results. That’s using a 33” height but at half tread your not likely going to be as accurate. Looks like its possible it may have 3:42, but I’d bet you’ve still got 3.07’s and here’s why, torque converter slip in that th350. If you had a manual transmission I’d say 3:42’s are likely, but with the auto it’s normal to run a few hundred Rpms higher than a manual transmission with the same gearing setup. https://spicerparts.com/calculators/...rpm-calculator
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Thanks! I had not considered torque slip. The truck isn't as big of a dog off the line as i thought it would be if it had 3.07s. Don't get me wrong. Its not real quick.
Ill pull the covers to confirm. Any ideas on a ratio box to get speedo more accurate? [QUOTE=57taskforce;8900179]Well, using the calculator below, it looks like with 3:07s you’d be running approximately 76-77 mph at 2400 thru 1:1 high gear. With 3:42’s you’d be closer to 69-70. This is all estimations though because the actual tire size is going to change the results. That’s using a 33” height but at half tread your not likely going to be as accurate. Looks like its possible it may have 3:42, but I’d bet you’ve still got 3.07’s and here’s why, torque converter slip in that th350. If you had a manual transmission I’d say 3:42’s are likely, but with the auto it’s normal to run a few hundred Rpms higher than a manual transmission with the same gearing setup. https://spicerparts.com/calculators/...rpm-calculator[/QUOTE]
#4 | |
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
It is backwards from what I would expect too. There must be separate issues. I'm thinking the ratio box is wrong and the speedo head may need rebuilt or replaced.
