06-06-2021, 10:30 AM | #1 |
WTB: Brake pedal assembly & Steering support pieces
I need a brake pedal assembly for my 68. Good driver condition is perfectly fine. I would prefer auto setup vs manual but I could make either work.
Also looking for the pieces for supporting the steering column. My zip is 46167 for shipping purposes. Let me know what you've got. |
06-06-2021, 12:30 PM | #2 |
Re: WTB: Brake pedal assembly & Steering support pieces
I have everything out of a 72 if that's the same, if so I can get some pictures.
06-06-2021, 01:35 PM | #3 |
I believe it is the same. I'd appreciate some pictures.
06-06-2021, 02:09 PM | #4 |
Here is what I have
06-06-2021, 02:11 PM | #5 |
I should have the other 2 pieces for the steering column at the firewall
06-07-2021, 07:42 PM | #6 |
How heavy is the rust? That may be a little rougher condition than I am looking for.
06-07-2021, 07:47 PM | #7 |
It's not really bad but I have several, it's just the first one I came to. I'll pull a better one tomorrow and get you a picture. 40 plus shipping, if still interested send me your zip and I'll get a shipping quote while I'm at it.
06-07-2021, 10:18 PM | #8 |
Aren't the column pieces different for a 67 / 68 because of the hand operated emergency brake? When the General went to the foot operated brake the column pieces had to change to support the column. Just trying to help out, not an expert with having a 71.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 06-07-2021 at 10:30 PM. |
06-07-2021, 10:39 PM | #9 |
Yes you are right. That piece is definitely different. I think the other ones I need are the same though.
06-07-2021, 10:38 PM | #10 | |
The pictures are the specific steering brackets I also need. I do have the main bottom plate one that mounts under the brake pedal bracket. |
06-07-2021, 11:05 PM | #11 |
Ok, I will pull a cleaner one tomorrow, I should have all 3 brackets also
06-08-2021, 08:00 PM | #12 |
Here is what I have, I'll grab a quote in the morning, I ran out of time today.
40 brake pedal 25 for the 3 brackets |
06-08-2021, 08:34 PM | #13 |
Yep let me know on the shipping quote. As long as it isn't too outrageous I'm in.
06-09-2021, 01:25 PM | #14 |
06-09-2021, 02:25 PM | #15 |
Yep. I'll take it.
PM me where to send the money. |
06-09-2021, 02:46 PM | #16 |
