C-20 Master Cylinder leaking
Morning Guys I've got a 72 C-20 daily driver I brought back from the grave every time I run this truck my brake fluid leaks out of the cover on the master cylinder I've replaced the gasket twice how can I fix this problem? It's lookes like it's not level? Thanks Saddletramp
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: C-20 Master Cylinder leaking
I had a similar issue once..... my memory isn't helping much but I think it had to do with the cap not sitting down all the way. Seems like it took some minor trimming to get it to seal properly.
Sorry I'm not more help, with any luck someone else will jump in here.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Sep 2014
I had a similar problem and ended up re-arcing the wire retention hoops to load the cap tighter.
Thanks for the response guys I'll tweet the arms that hold it down .saddle tramp
Topic discussed in this thread as well. http://67-72chevytrucks.com/vboard/s...d.php?t=809178
Morning Thanks for the info I'm going out to my Truck to see what I can do appreciate it.saddletramp
