![]() Join Date: Aug 2019
Yukon Radio
Does anybody else have trouble with a Yukon radio draining the battery.
![]() Join Date: Oct 2009
Re: Yukon Radio
i have not - why are you suspecting the radio specifically?
Though not common, one thing worth checking is to make sure your underhood utility light actually shuts off when closing the hood - it won't gravity rock and click off until hood is almost shut, so you kinda gotta watch closely. Not likely the culprit, but worth checking. Best way to chase a batt drain is with a voltage drop check as you (or hopefully an assistant) pulls individual fuses one at a time. |
Old Heap Driver
Re: Yukon Radio
Be sure to check the sunvisor lights as well, mine were staying on due to a bad door switch.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Re: Yukon Radio
S10fan, Thanks I will do that.
Re: Yukon Radio
Todays up date. While trouble shooting, the battery went bad. They replaced it under warranty. No under hood light. I will check the voltage tomorrow morning.
Moderator
![]() Join Date: Oct 2008
Re: Yukon Radio
Bad door switches will cause the BCM to not put various higher current draw components into sleep mode.
If your replacement battery doesn't fix the problem it'd be worth paying attention to how long it takes the dome lamp to shutdown after you close the door.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Re: Yukon Radio
The dome light goes out in e few minutes. When I have the hatch open the light stays on. Isn't it supposed to go out after awhile?
Moderator
Re: Yukon Radio
It's supposed to go to sleep eventually but a bunch of BCM functions stay more active til the doors, trunk, and hood are closed.
