upper windshield panel
Who has had to repair this? this is on my to do list after the first. My windshield is a mess but I know this will need fixed to replace it. Any hints or tips would be appreciated...
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: upper windshield panel
There are some posts of ones doing it. But I can't remember if they used the patch panel that's available to purchase, or they just used a donor cab.
I'll see if I can find a the threads.
Here's a few that might help:
https://67-72chevytrucks.com/vboard/...highlight=Roof . https://67-72chevytrucks.com/vboard/...highlight=Roof . https://67-72chevytrucks.com/vboard/...highlight=Roof . https://67-72chevytrucks.com/vboard/...highlight=Roof . https://67-72chevytrucks.com/vboard/...highlight=Roof
I just replaced this on my 61. Other than the part needing to be widened about a half inch it wasn't too bad to install, although my roof skin was removed.
Check out my build . I just did the patch above the windshield inside cab and the outer eyebrow. Then the rear over hang above back window . It always snow balls fast once you sandblast https://67-72chevytrucks.com/vboard/...d.php?t=825083
I have done this, inside and outside. I used the patch panels i could purchase and it was not to bad and i am NOT a body guy. Just do not hurry through it or you will get very frustrated, take your time, check twice, three and four times, then cut and replace.
John 3:16 - Saved me... God Bless |
I have replaced this panel on my 66 using the panel they sell for the 60-63. It was not that hard to do. As has previously mentioned, it has to be widened about 1/2" to use on the 64-66 bodies. While it is off, you can spend some time rustproofing the roof and ceiling as well.
