01-25-2022, 12:21 PM | #1 |
DEAL ALERT: 1968 C/10 restomod at barret jackson on thursday
This is not a for sale post.
I built this truck back in 2016 with the help of this group. Unfortunately, I never had the time to do a build thread. I sold it last summer for $40K to what turned out to be a high end car flipper. He's running it across the auction block this thursday close to some other well know builds off this site. This could be a steal of a deal due to the fact that I never did any paint work and its a good 20 footer in appearnce. Mechanically, IT IS DIALED! Link to the auction. https://www.barrett-jackson.com/Even...-PICKUP-251912 Build stats... Original Colorado 1968 short wood bed C/10 -all original Colorado metal with the exception of the ( bed header panel, wheel tubs & rockers). Features -Aluminum 5.3l (327) LS engine -TR6060 6 speed transmission w/ hydraulic clutch -5 lug 4 wheel power disc brakes -No Limit Engineering ( NLE) suspension throughout -NLE power Rack & Pinion steering -Stainless steel 2.5” custom exhaust -Vintage Air heat -Optima battery relocated passenger side frame rail under bed -Complete composite bed -No Limit Engineering underbed mounted fuel tank. -3” front, 5” rear static drop (CPP springs & ridetech adjustable shocks) Engine/Driveline -2012 all aluminum 5.3L LS engine with 243 heads. Completely stock with VVT, no DOD, complete GM truck front drive system. -MSD atomic EFi sytem -2014 Tremec TR6060 transmission w/ GM LS3 hydraulic clutch -CORE/ Hurst shifter assembly - Custom Driveshaft shop aluminum driveshaft ( $1000 w/ C/V input from trans). -Original 12 bolt rear end modified by Mark Williams Enterprises. ( 4:10 gear, eaton posi, MW master line axles, shortened axles for correct wheel offset, c-clips eliminated, `1350 series yolk, HD aluminum rear cover). -New U bolts - 20” ridler wheels ( 255 front 295 series rear). Fuel System -NLE under bed mount Baffled aluminum fuel tank. Serviceable from under the truck -Walbro 255lph fuel pump -Holley Hydromat system -PTFE return style fuel line system Chassis - Factory original short bed frame rails - NO REAR C NOTCH!!! - ALL rivets removed/replaced with grade 8 hardware - NLE front/rear frame cross braces - NLE transmission brace - CPP Trailing arm crossmember - blasted/powder coated radiator core support - front wheel tubs were blasted/powder coated/raptor liner on the underside Suspension Front - CPP 2”drop spindles - CPP 1” drop spring - MOOG ball joints - Energy suspension bushings - All parts blasted/powder coated - NLE front sway bar ( custom heim joint end links) - RIDETECH adjustable shocks - POL front shock mount relocation Rear - Stock powder coated trailing arms - Energy suspension bushings - NLE Pan hard bar - NLE shock relocation - 2” CPP lowering block - 2”CPP lowering springs Brakes -CPP big brake kit ( 13” front, 12” rear) -Stainless braided lines - Power brake booster -CPP brake bias controller -In line tube stainless steel lines everywhere -Hawk HTS brake pads -Parking brake assembly functional Interior -Custom blue/black hounds tooth seat cover w/ new foam - Original GM 67’ fold forward bench seat (blasted & painted) -Custom vinyl/sewn door panels ( NOT welded vinyl reproductions) - ALL NEW weather stripping - Roll up windows and vent windows have been completely restored -GM logo 3 point belts ( 2 point in the center) - New matching dash pad -Period correct silver loop carpet from ACC - Matching loop floor mats from ACC - Complete Painless Wiring harness interior, engine bay & chassis - Nu Vintage Guage set - Vintage Air heater/defroster - New window seals - ALL original tinted glass ( vent windows are reproductions) -IDIDit tilt steering column w/ GM reproduction corvette “wood” steering wheel Cooling System - Full size brass reproduction radiator - GM hoses - 180 degree thermostat - DUAL spal electric fan assembly controlled by the Atomic MSD system Exhaust -Doug Thorely Tri Y coated headers - custom 2.5” staines tubes (with H pipe) - Borla Pro XS mufflers ( turned down before rear axle) Body -Colorado rust free original metal truck ( Bed header panel, bed wheel tubs, rockers are AMD metal). -Repainted 7 year ago by the previous owner -Original 50th anniversary fender badges -reproduction grill and headlight surround trim -reproduction chrome bumpers - Blasted/ powder coated hood hinges - side trim and turn signal delete by previous owner BED -support rails were blasted/powder coated -bed wood upgraded to high grade capped decking material -ALL factory bed strip mounting points were reused ( no new holes) -136 Stainless steel fasteners were assembled w/ anti-seize - New AMD wheel tubs ( raptor liner applied to the underside). -New AMD header panel - original tail gate -new bed mount isolators Last edited by Bowtiguy; 01-25-2022 at 12:49 PM. |
01-25-2022, 12:44 PM | #2 |
Re: DEAL ALERT: 1968 C/10 restomod at barret jackson on thursday
Kinda cool, but it will sell for more than it's worth. Not my definition of a deal, but I'm sure the buyer will think so.
01-25-2022, 12:47 PM | #3 |
based on Mecum sales last week, I wouldnt be surprised. He sold $5.5 mil worth of cars/bikes last may. so hes just playing around at this point. I have a buddy there this week. If it goes for under $xxK, ill buy it back.
02-03-2022, 01:35 PM | #4 |
Turns out he got what I sold it to him for, minus shipping & 10% to Barret Jackson.
Now, I have a NEW Cover Craft indoor car cover I need to find a new home for. I never got a chance to install it. Anyone looking for one 1/2 off? |
02-03-2022, 01:57 PM | #5 |
What sideview mirrors are those?
02-03-2022, 02:05 PM | #6 |
I might be. Can you PM me a price.
02-03-2022, 02:10 PM | #7 |
02-03-2022, 02:08 PM | #8 |
02-03-2022, 02:17 PM | #9 |
Link says it sold for $44,000.00...not much profit on that one...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
02-03-2022, 02:42 PM | #10 |
You need to be a member to post items to sell.
Please contact a moderator to set things right.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-03-2022, 03:59 PM | #11 |
02-03-2022, 03:01 PM | #12 | |
The Auctioneer fees are 15%, (I think, And I think there’s other fees too), so if that’s the case, seller’s take home was around $37k This doesn’t include the advertising, marketing, and transportation fees Beautiful Truck though, and a well done build. |
02-03-2022, 03:59 PM | #13 | |
02-03-2022, 04:41 PM | #14 | |
