Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-27-2022, 10:31 PM   #1
HotRod4me
Winging a 1971 K5 Blazer L96 6L90 Swap
Hi, everyone. Been watching this site for a long time putting my build together in my head. Picked up a tired Hugger Orange 1971 Blazer and a parts truck over the summer.
So here were go- I love the old patina paint on the truck so I think I'm going to leave the body and paint alone for now. The drive train is a different story. I plan on doing a 2" spring lift, new stock 33" tires and a L96 motor with a 6L90 transmission behind it.[ATTACH]Attachment 2162428[/ATTACH]
HotRod4me is offline   Reply With Quote
Old 01-27-2022, 11:38 PM   #2
72gmguy
72gmguy's Avatar
Re: Winging a 1971 K5 Blazer L96 6L90 Swap
Sounds cool. I will be watching!
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 01-28-2022, 09:02 AM   #3
68panelman
68panelman's Avatar
Looking good
68panelman is offline   Reply With Quote
Old 01-28-2022, 09:07 PM   #4
HotRod4me
This is going to go pretty fast for a while. I've been working on it for a little while and now just starting to post the progress to document the adventure and possible help others doing something similar along the way.
Old 01-29-2022, 12:01 AM   #5
HotRod4me
Tear down started
Old 01-29-2022, 12:13 AM   #6
HotRod4me
Motors out
Old 01-29-2022, 12:25 AM   #7
HotRod4me
Anyone looking for a motor
Old 01-29-2022, 10:23 PM   #8
68panelman
68panelman's Avatar
Cranking right along. I'd take that motor if you were closer. Keep up the good work!!!
Old 02-02-2022, 08:20 AM   #9
jaros44sr
jaros44sr's Avatar
Looks great, nice work
Don't forget the poly mounts on.the motor, I've read where they don't play well, if you mix poly and rubber
Now would be a good time to add hydra boost, it will stop the big tires w/o.a problem, also, consider a 3 pice cross brace motor mount, if you ever have to drop your oil pan, you will be glad you did.
Now I want drill and and cross vent my front hubs, these forums are a slippery slope
Thanks for posting up, gives me hope and incentive thar someday I'll finish mine
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-02-2022, 10:44 PM   #10
Kenz72K5
Looks Good, will look in to see how your doing, My 72 K5 I purchased a year ago already had the LS1 and 6L90 but alot of things I still wanted to do such as Electric windows, door locks, 1 piece window etc. has a 6 inch lift that I would like to lower to 2-3 inch.....
Kenz72K5 is offline   Reply With Quote
Old 02-03-2022, 01:15 AM   #11
HotRod4me
Thanks for checking out my build guys. I already purchased a Dirty Dingo motor mount for that exact reason and the rubber motor mounts. Now I'm second guessing those and considering the polyurethane ones. I'm at a good point to swap them out now, so thank you again for the tip. That is exactly why I love these forums and other builders input.
Old 02-03-2022, 01:19 AM   #12
HotRod4me
Picture of the new drums and gas tank.
Old 02-05-2022, 12:13 AM   #13
HotRod4me
Transfer case rebuilt, Advanced engineering adapter installed for the 6L90 and ready to go. Now I just need to figure out a shift linkage adapter.
Old 02-05-2022, 03:34 PM   #14
HotRod4me
In tank fuel pump from Tanks Inc installed with Corvette pressure regulator and new shoes on stock rims. Love the look of these tires!!
Old 02-22-2022, 11:28 PM   #15
1rippen6
How did you modify your tank for the fuel system? Thanks
1rippen6 is online now   Reply With Quote
Old 02-23-2022, 01:35 AM   #16
HotRod4me
Thanks for checking out my build 1rippen6. The tank modification is explained further in the last post on the first page of this build thread. I used the stock tank and cut the hole for the sending unit with a large hole saw. After the hole was cut I welded in the retaining ring to make sure it was a solid mount. Please let me know if you have any further questions or need any measurements.
Old 02-23-2022, 01:38 AM   #17
1rippen6
I'm good, I don't know how I missed it the first time, lol.
Old 02-23-2022, 01:50 AM   #18
HotRod4me
Made a little more headway tonight. Got the front sway bar figured out and mounted. Since I did a 2" suspension lift, I had to reconfigure the way the sway bar mounted. I extended the bolt and used an 1-1/4" spacer. To mount it to the frame I ended up using a couple old transmission mount brackets I had laying around. The brackets gave me roughly 1" more clearance and helped me clear the brake lines. Almost looks factory.
Old 02-27-2022, 11:01 AM   #19
Tuff Gong
Tuff Gong's Avatar
Your truck is looking amazing. What size tires did you put on?
Tuff Gong is offline   Reply With Quote
Old 02-27-2022, 02:25 PM   #20
HotRod4me
Thanks for the encouragement. I ended up going with Firestone Destination LT33x12.50rx15 tires. I obviously haven't drove on them yet, but think they have a good aggressive look and with the tread pattern I wont have to much road noise while driving. I was on the fence between these and BF Goodrich. I see a lot of guys running the BF tires on their trucks, but have had good luck with Firestones in the past- plus they were roughly $200 cheaper for the set of four.
Old 02-27-2022, 02:32 PM   #21
HotRod4me
Made very small steps forward today. Ended up getting some heat shield protective boots for the plugs. The wires sit pretty tight against the shorty headers.
Quick question for guys that have done builds in the past. Has anyone had the exhaust system built without having the body on the frame? Just worried about clearance issues if I have this done without the body on. All input is welcome.
Thanks,
Andy
Old 04-10-2022, 10:46 AM   #22
13jraven
13jraven's Avatar
Take this with a grain of salt - A few years ago, I did an L96/4L80 with a 3.73 gear in a NASCAR inspired late 70s C10 with a Fitech set up.
Set the motor and trans without the cab on the frame and had no issues with the cab clearance. I know 2WD vs 4WD and 1st vs 2nd gen - hence the "take this with a grain of salt"
The issue I had is the L96 ran hot and was a thirsty ***** with the 80 pound injectors and the tune. I had to go back and do some heat displacer matting on the firewall and the inside of the cab.
My tuner buddy swears by the 6L90 - says they handle a ton of HP/TQ in their stock form. Way past what they are rated for.
13jraven is offline   Reply With Quote
Old 04-14-2022, 11:33 PM   #23
HotRod4me
Thanks for the input 13JRAVEN. I think the clearance will be good and love the square body tribute truck.
Had a little stall on my build while waiting for my wiring harness and ECM to come back. I've been spending my time getting my wife's 1968 Chevelle SS motor freshened up and converting the front brakes to disc brakes. Hoping to get the exhaust built for the Blazer in the next couple weeks and then fit up the body. I'll keep you posted with hopefully good progress on both.
