![]() Join Date: Oct 2020
Altman Easy Latch and Door Adjustment
So I installed the Altman Easy Latch and was really pleased with how it came out. I have fiddled with the door and just cannot get it to line-up with the cab.
The door is a reproduction door, so I know there will be some 'anomalies' in how it fits, but I want to get it as close as possible. I will say, I temporarily installed the door seal (slip-on type) to see what effect it has. I can get the door in square, but the door from about 6 inches below the gas cap up to the drip rail is about 1/8" - 3/16" proud of the cab along the door seam. Being a repop door, I know that the fit isn't going to be perfect, but I would like to get it as good as I can get it. Is this something I am just going to have to live with? The truck by no means was assembled with precision...there are several build mistakes that I have corrected, but a couple I have not due to the complexity of the repair. I have just decided to leave those. Any ideas/thoughts are welcome. Here are some pics of what I have: |
![]() Join Date: Dec 2013
Re: Altman Easy Latch and Door Adjustment
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#3 | |
Almost Satisfied
![]() Join Date: Mar 2002
I have the altman latches and one repop door. Mine also fit like yours near the gas filler. Everywhere else was good. With a lot of work it was able to be adjusted and massaged to fit better during paint and body.
My doors do not close and open as effortlessly as I had hoped. Still slamming them and they are hard to open from the inside. It has gotten better as the seals broke in but still not what I had hoped for. If you find a fix let me know.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Did you get them fixed so you don't have to slam?
