![]() Join Date: Oct 2014
TBI woes
Hello folks. I normally post over in the 73-87 section, but since I have a TBI setup in my 1982 GMC, I figured I'd get more help over here, since 1987 was the first year for TBI trucks.
A few months ago I bought a 1987 Chevy R20 with a TBI 350 and manual transmission to use as a parts truck for my 1982 GMC. It seemed to run okay but the throttle was extremely sticky due to the flappers in the throttle body sticking. I tore down the TBI, bushed the throttle shafts, replaced the injectors and IAC valve (both with Standard Motor Products), and did a thorough cleaning, making sure to clean all vacuum ports and the IAC passage. I replaced every gasket, seal, and the FPR diaphragm. After doing so, I've never really been able to get this thing to run right since then. Here are a few problems I can't get ironed out. I have WinALDL and no codes are present. At idle, the RPM fluctuates up and down. If I depress the throttle a little bit, the RPMs still fluctuate, just in a higher RPM range than in idle. I know this is either due to low fuel pressure, a vacuum leak, an IAC problem, or TPS problem. Thing is, I have a new fuel pump + hose, all new fuel lines, fuel filter, all new intake gaskets, and new vacuum lines. I've checked fuel pressure (11.5 PSI), and checked for vacuum leaks by spraying starter fluid around every possible source for a leak and found nothing. I've tried plugging every vacuum port with no luck. I have the timing set at 0 degrees (with the bypass unplugged). I must have done the IAC reset procedure 50 times, I've put the old injectors and IAC back on, replaced the TPS and set it to .5 volts at idle, all with no change. The thing is, if I turn the idle screw up so it revs around 900 at idle, it seems to stabilize (only when in closed loop), but the IAC counts are zero. Another thing I can do that seems to help is unplug the CTS which richens the A/F mixture. I can't tell if it's the richer mixture or the slight raise in RPM that's fixing the problem though. When the engine is cold it idles fine until the coolant temp reaches maybe 100ish degrees, then I get the fluctuating idle (until it goes into closed loop mode.) Another thing is when accelerating, I have a very distinct, but momentary misfire at a certain RPM. It only happens under light to moderate acceleration though, right at around 2200-2300 RPM, and it's only for a split second. The best way to describe it is it feels like the engine shuts off for a split second then turns back on almost instantly. It doesn't feel like a typical lean-sputter, or backfire. I thought maybe this was a TPS problem, but it does it on all three TPS sensors that I've tried, all at the same RPM under same conditions. The last thing. When the engine is cold, it drives like crap and has no power it feels like, and every now and then I get a CEL but with no codes. If I shut the engine off and shut it back on right away, the CEL turns off, and it seems to be fine after that. None of this happens after it's warmed up beyond maybe 120-150 degrees. As I mentioned above, it idles fine when cold. Since having these problems, I've replaced the TPS, MAP, CTS, knock sensor, EGR valve, PCV valve, O2 sensor (3 wire unit), wire harness (Painful Performance Swap harness), distributor (and all internal components), spark plugs, wires, every single intake/exhaust gasket, etc. Pretty much everything short of the EGR solenoid, the ESC, and the PROM. All components used apart from the IAC and injectors are all ACdelco. I've even switched out the computer from another truck that I have with no luck. I know this is long winded, but I am genuinely stumped, and would love some input. As mentioned, I have WinALDL and can datalog and post it on here if needed. I'm also open to the possibility that I did something wrong by either not doing a test/reset procedure properly or didn't install something correctly, etc, so if you think I should recheck something that I've already messed with, just let me know. Last edited by 66gmcguy; 06-04-2022 at 01:41 PM. |
Re: TBI woes
I wish I could help but you already know more about the TBI than I do. I've never had to service that on any vehicle I've had with it. I'm sure some insight will be coming along
#3 | |
Re: TBI woes
How about the temp sender? My temp sender worked, but the range was off. Also did you try to induce a vacuum leak by pulling a line to see how it affected things? This sounds like a TBI swap, how is the wiring, maybe a loose ground? Just grasping at straws here...
'47 Panel to '88 K2500 Frame Swap Mechanical Speedometer Drive Solution 1947.2 1 ton Chevy Panel 1955.2 Chevy 6700 Bus/RV 1990 Chevy K1500 |
#4 | |
Re: TBI woes
As far as the rest of the wiring is concerned, I don't believe that to be the issue, since all of the same problems occurred when the engine was still in the donor vehicle with the old harness. I have the same problems even with my new harness. I will check the CTS tonight and report back. |
Re: TBI woes
Make sure the PROM (chip) in the ECM matches your engine size.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
Re: TBI woes
#7 | |
Re: TBI woes
If the light comes on there should be a code. Maybe the computer isn't getting constant power for the memory.
Re: TBI woes
I'm not sure if that's the case. I only think this because the computer retains fault codes even after shutting the truck off for a while and the codes only go away after disconnecting the battery for a minute or so.
#9 | |
Re: TBI woes
The computer should retain the codes but it won't if you don't have constant power to it. So it gets power to run but shutting it off removes the only power it gets, pretty much like disconnecting the battery. You said the light comes on but no codes stored.
#10 | |
Re: TBI woes
I just drove it around again after disconnecting the battery to wipe the memory and clear any codes, and sure enough, the CEL came on again for code 44. If I shut the truck off and shut it back on right away, the CEL turns off. Like I say, this situation only happens if I drive the truck before it fully warms up. If I let it warm up before driving it, this doesn't happen. So to circle back, there IS constant power to the computer even with the key off, as it does store codes. so that doesn't seem to be the problem. I should emphasize that I don't get that code at all if I let the truck warm up before driving it, AND after I've driven it around under various types of loads (I have city/mountain/highway driving everyday during my commute.) So the lean condition probably explains the poor drivability with a cold engine, but I don't think it explains the other two problems I'm having, because even when the idle fluctuates around, I don't get any codes. |
Re: TBI woes
It set a lean code more then once and a lean condition fits some symptoms.
Is the three wire oxygen sensor a Bosch unit? If so I suspect it is the problem. I would try unplugging the oxygen sensor and seeing how it runs as it warms up. If the system is seeing oxygen sensor readings that show the sensor is warm enough to use, it will be reaching closed loop operation when the engine is not as warm as it would be if it had a one wire oxygen sensor. Let us know how it runs with the oxygen sensor unplugged.
Re: TBI woes
#13 | |
Re: TBI woes
My oxygen sensor would go into negative voltage, making the computer think it was running lean so it would dump the maximum amount of fuel it could into the engine. Within what voltages does it operate?
![]() Join Date: May 2006
Re: TBI woes
You got all complicated at first and I didn't know how to reply to your post. Now that there are comments that are weaned out I'll tell you what I think it is since it sounds like the same symptoms I experienced when I swapped out my original 305 engine in my truck for a 350. It will run but it will definitely give you lean codes and stumble. You need the correct PROM/ Programmed PROM for the engine you are running. It sounds like you've done everything but this. That's one of the things you have to consider in this day and age of computer controlled vehicles.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
#15 | |
Re: TBI woes
It's worth it for me to note that I didn't just cobble the system together from junkyard parts from various different trucks. Everything (including the engine) came off the same truck. The donor truck was an 87 R20 (2wd 3/4 ton) with a manual transmission. The truck it's in now is an 82 K20 (4wd 3/4 ton) with a manual transmission, so that means that the PROM is a close match for my truck. Last edited by 66gmcguy; 06-04-2022 at 01:42 PM. Reason: added note about fuel system. |
#16 |
Re: TBI woes
Just glancing down a couple times at WinALDL while driving to my shop this morning, I saw anywhere from .004 volts (when coasting) and as high as .894 when under load. I will try and get a data log today that will hopefully give me some better data.
#17 |
![]() Join Date: Mar 2015
Re: TBI woes
A good friend of mine had issues with his TBI. Turned out their are two systems and they require different fuel pressures and as a result different pumps. The auto parts store sold him an incorrect pump. He changed the pump and everything went back to normal.
Would be interesting to see the results of a smoke machine test. Cheers. |
#18 | |
Re: TBI woes
And yes, I concur. I would have done that already but since installing this system in my truck, I haven't had time to bring it to a shop to have them test it. If I can't find the problem by the time work slows down a little bit for me, I will get a smoke test. |
#19 | |
Re: TBI woes
NOTE: Earlier I suggested to try running with the vacuum hose plugged to the EGR because there are different types of EGR systems depending on the gross vehicle weight and there could be a mis-match of parts from two different types of EGR systems causing problems. I have run into this problem in the past.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. Last edited by ChevyTech; 06-04-2022 at 05:49 PM. Reason: Add more |
#20 | |
Re: TBI woes
The EGR valve I bought is ACdelco 214-5073. I picked it out based on the listed GVWR, and because it said this particular one is for trucks with manual transmissions. But of course, it's still possible I picked out the wrong one. Also, this is the EGR solenoid I have. I guess these aren't as common as the other type that has two wires coming out of the back. This one also connects to ported vacuum, whereas the other one connects to full manifold vacuum. |
#21 |
Re: TBI woes
That photo is of a "Port" EGR Electronic Vacuum Regulator Valve.
An AC-Delco 214-5073 is a negative back-pressure EGR valve. These parts are NOT compatible. That is the wrong EGR valve for a very different system. A negative back pressure solenoid is opened when EGR operation may be needed and passages inside the EGR valve modulate the opening. On a port EGR system the Electronic Vacuum Regulator Valve pulses like a fuel injector to modulate the opening on the EGR valve. Port EGR systems are used above 8500 GVW. My notes show AC - Delco 214-5364 as possible EGR valve that might fit your truck, GM number 17087185. There should not be any EGR operation at idle, so we found something wrong, but I think there are other problems. I believe all the trucks above 8500 GVW used a distributor module with a less aggressive advance curve.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. Last edited by ChevyTech; 06-04-2022 at 08:59 PM. Reason: Ad more |
#22 | |
Re: TBI woes
From what I've heard removing the smog pump will throw off the oxygen sensor readings. Maybe you need a PROM from a truck without a smog pump.
#23 |
Re: TBI woes
I will look into that. I have a 1989 R3500 with the same engine as my truck, same EGR system but with no smog pump (federal truck.) I think I will swap computers/PROMs and see. The only thing is, the R3500 has an automatic (TH400), whereas my truck has a manual transmission. I'm assuming the fuel maps are different. This won't hurt my engine, will it?
#24 | ||
Re: TBI woes
#25 | |
Re: TBI woes
Pretty sure ChevyTech has said before that the computer will learn what it needs to run right, the programming just starts it closer from no memory.
