03-21-2023, 01:47 PM | #1 |
Tach help please
Anyone familiar with this tach? 6-8 cylinder??
03-21-2023, 04:18 PM | #2 |
Re: Tach help please
I can't offer much in the way of which engine this tach will work for, but I can say it looks to be a later unit if its factory (i.e., without a transmitter box).
I did find this post that includes a picture of an OE-1 by member 1963c-10. Not sure if they are still on here or if that was their tach that was pictured. I believe what you have is a V8 tach, but I am not certain. https://67-72chevytrucks.com/vboard/...=392461&page=4
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
03-21-2023, 04:57 PM | #3 |
Thank you,I appreciate the help!!
03-21-2023, 05:04 PM | #4 |
I guess my next quest will be can i make it work with an hei dizzy? Nothings easy lol
03-21-2023, 05:44 PM | #5 | |
https://ashlocktech.com/tach-adapt-1 |
03-21-2023, 08:18 PM | #6 |
Thank you!
03-23-2023, 12:01 AM | #7 | |
03-23-2023, 11:14 AM | #8 |
If that tach works with a points-type distributor, it should work fine on an HEI. There is a TACH terminal on the HEI, just run a wire there from the DIST terminal on your tach.
03-23-2023, 11:19 AM | #9 |
03-23-2023, 01:16 PM | #10 |
Ok,so I reached out to Bob at ashlocktech and he told me I should be fine with my DUI HEI dizzy. He went out of his way to research my dizzy to find out! As was mentioned above what a super knowledgeable and nice guy!! Thanks so much for the great info.
Dan |
