Old 05-04-2023, 06:44 PM   #1
Matt_50
Door lock
Getting lots of small things checked off the list.
Door lock was supposed to be one today. 1950 so it only has a passenger outer door lock.
Never had a key so I bout a new keyed one. Replacement was easy. But it doesn't work.
If I push down on inner door handle it locks the door as it should. But the key doesn't feel like it wants to turn all the way. Popped it back out. Used a screw driver of the same size and I cannot lock or unlock with the key.
Thoughts?
1950 Build
Matt_50 is offline   Reply With Quote
Old 05-04-2023, 07:16 PM   #2
mr48chev
mr48chev's Avatar
Re: Door lock
Does it work when the lock isn't in the door? Meaning, can you work the key back and forth with the lock out in your hand?
My ongoing truck projects:
Old 05-04-2023, 07:19 PM   #3
Matt_50
Re: Door lock
Yep. Full movement.
1950 Build
Old 05-04-2023, 08:46 PM   #4
joedoh
joedoh's Avatar
Re: Door lock
Thoughts?
the key does not unlock the "push down the inner handle to lock" lock. you lock the drivers door that way, then get out the passenger side, and use the key which when locked blocks the outside handle from opening the door and when unlocked lets the handle work normally.
and if you think about it, the key would have to push the inner door handle down to lock the door and up to unlock the door. there isnt any type of linkage like that.
i rebuilt some 41-46 door latch assemblies and I think i have pictures of the little cam in them that just blocks the outside handle from turning. while its not the same mechanism it is the same principle. the first year that the actual key locked the mechanism was 67. even the 52-55.1 door handles with the key in the button still work by preventing the button from working, not moving the inside handle. if you were able to lock both inside handles and get out somehow, you would not be able to get back in!
Old 05-04-2023, 10:19 PM   #5
fauXGT
fauXGT's Avatar
Re: Door lock
I replaced both worn out door latches with new ones. Took apart the old passenger one to find out what operated the lock. Took the new drivers side apart and duplicated in reverse the arm that has the space in the drivers side for it to lock. Just cut a lock hole in the drivers door and get it keyed the same as the rest. Wouldn't tolerate sliding across the seat every time. Took a weekend to do... but most of my psycho ideas usually take time.
Chip
'51 Chevy 3600 5 window
C4 Vette front/rear suspension & drive train
full Rusto-Mod
'92 GMC Sonoma GT VIN #0015
'91 GMC Sonoma GT extended cab 1 of 1
fauXGT is offline   Reply With Quote
Old 05-04-2023, 10:54 PM   #6
mr48chev
mr48chev's Avatar
Re: Door lock
The point that Joedoe made is "THEE" point. You don't move the passenger door handle to locked and close the door, you close the door and then lock it with the key. You only lock the passenger side door with the handle when you are inside and want the door locked.
Old 05-04-2023, 11:25 PM   #7
fauXGT
fauXGT's Avatar
Re: Door lock
If I'm reading MATT 50 correctly, the last comment was that whatever state the inside was in, the key wouldn't do anything(lock or unlock). The entire latch may be bound up not allowing the light action of the key, but even a screwdriver isn't working. It isn't a 'linkage' that operates the key operation, it is a lever that is sandwiched in the mechanism of the latch that stops or allows the outside handle from moving. If the lever can't move freely, the lock/unlock won't work.
Chip
full Rusto-Mod
Old 05-04-2023, 11:31 PM   #8
mr48chev
mr48chev's Avatar
Re: Door lock
It's time to pull the lock out and do some cleaning, lubing and looking.
Old 05-05-2023, 12:53 AM   #9
leegreen
Re: Door lock
excuse the thread jacking,
my '52 with push button doors, both inside handles will lock the doors, so as Joedoh suggests it is possible to lock both doors so you can't unlock from the outside. What is supposed to stop that from happening, is it a feature of the latch, inside handle or some adjustment I missed?
also, both inner handles, you only have to move them a small amount from the unlocked position to trigger the release of door latch, is that normal?
leegreen is offline   Reply With Quote
Old 05-05-2023, 01:08 AM   #10
joedoh
joedoh's Avatar
Re: Door lock
hmm. i read it as he locked the door with the door handle and the key would not unlock it. which it never will, was my comment, different systems.
i will have to go outside in the morning but i dont think it is possible to lock an open door using the inside door handles. it will only lock when its shut
Old 05-05-2023, 07:45 AM   #11
Matt_50
Re: Door lock
I played with the door. Opened, closed, window down ect. The little part that does the locking looks the same on the driver door. To see it work with the door open I had to manually rotate the part that hits the latch back and forth. With the lock or a screwdriver I couldn't get it to lock. The key only moved maybe a quarter turn until it found resistance. I guess I need to pull it all out and see if anything is in a bind.
1950 Build
Old 05-05-2023, 08:08 AM   #12
joedoh
joedoh's Avatar
Re: Door lock
nothing is in a bind, it is working the way it is supposed to. in fauxgt p[icture you can see the locking cam only has about 80 degrees to turn and lock (by blocking the OUTSIDE handle from turning) or unlock (by letting the outside handle turn normally). because it is only turning that little cam, there will be barely any resistance to it turning and it is more a "turn almost a quarter and its locked" than feeling it turn anything. it is not connected to the part of the door that turns the inside handle, and thats important too because even if you lock the door with a key you can still open it from the inside.
Old 05-05-2023, 02:29 PM   #13
leegreen
Re: Door lock
Originally Posted by joedoh View Post
I will have to go outside in the morning but i dont think it is possible to lock an open door using the inside door handles. it will only lock when its shut
I'd certainly like to know what you find. As far as I can see there is nothing to prevent it, at least with the combination of parts in my doors.
Some old manual links of interest to the general topic of locks:
pre 52 shop manual link to section about locks
http://chevy.oldcarmanualproject.com...51ctsm0114.htm
54 shop manual locks
http://chevy.oldcarmanualproject.com...4ctsm0111.html
truck owners manuals links to lock descriptions below.
there are some interesting variations on how the outside key works. All versions I have seen just describe the inside handle as 'to lock either door from the inside it is only necessary to move the inside remote control handle forward (the '48 version says 'up'). So none really answer my question about locking yourself out.
51 owners
http://chevy.oldcarmanualproject.com...er/51tom11.htm
52 owners manual
http://chevy.oldcarmanualproject.com...er/52tom11.htm
53 owners
http://chevy.oldcarmanualproject.com...er/53tom11.htm
lock cylinder key has different action for '52 vs '53, my '52 must have '53 lock cylinder
Old 05-05-2023, 07:03 PM   #14
joedoh
joedoh's Avatar
Re: Door lock
i have a 54 in the driveway and totally forgot my "i will try in the morning" until you responded.
both drivers and passenger doors unlock after shutting the door if you push the inside handle down (locking it) with the door open and then shut the door. the interior handle moves up almost imperceptibly but its enough to unlock the door, I had no issue opening a "locked" door after shutting it. I tried it several times on both sides.
I have a 49 at the shop that still has doors I will try it on a drop handle too.
this makes sense, too, because we dont have 10,000 threads from different people about locking themselves out. the "key unlocks the inner handle" myth would be a lot more prevalent if it was possible to lock an open door with the inside handle.
Old 05-06-2023, 08:47 PM   #15
mr48chev
mr48chev's Avatar
Re: Door lock
One thing about it, you aren't going to lock the keys in the truck.
