Fouling plugs
I am fouling plugs on cylinder 1 & 2. I am running NGK R5671A-7 plugs. Should I change these?
350 Gen 1 bored 40 0ver, 400 crank, 750 double pumper. New build mostly idle time, around the block a couple times, but not driving daily yet
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
![]() Join Date: Mar 2003
Re: Fouling plugs
The 750 double pumper may be putting too much fuel into the engine
Re: Fouling plugs
Its not even started to break in. Verify timing and run it. Check the plugs again after a couple hundred miles.
Double check for a vacuum leak on the back cylinders. A brake booster can leak while still providing boost. |
It depends on how they're fouling ~ oil or fuel ? .
What's the gap ? . Points or breakerless ignition .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#5 | |
Re: Fouling plugs
VWNate1
Should be HEI 43-45 gap. As said by VWNate1. And I would use a vacuum Gauge to adjust the carb check the timing. Did you have the head seat seals changed make sure the plugs are not oiling fouled. Go back to basic re-ID: the plugs again to find out the problem.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Re: Fouling plugs
It is carbon fouled
HEI Distributer I think the gaps are about 0.55
Okay ;
Now you're getting some where . Time to check the timing and then look at the fuel system as carbon usually means running too rich and there are myriad simple reasons for this .
Re: Fouling plugs
I have heard my carb is too big
Double pumpers are used for manual race cars, not drivers
Re: Fouling plugs
New build, mostly idle time you said.
We’re assuming you did the required cam break in. Normally 2000 rpm for 20 minutes. A double pumpers not too big. If the floats are set too high or the power valve is not the right one you can get a rich carb. Lack of enough timing can cause fouling too. |
Re: Fouling plugs
I did the proper break in I have an 8.5 power valve & 73 main jet and a 77 secondary jet
Re: Fouling plugs
What’s your idle rpm?
What’s your initial timing? What’s the vacuum reading at idle? What do the plugs look like on 7 and 8? |
Plenty of double pumper carbys are factory stock .
Yours -may- be too big, keep following the basic questions here, in my long career most times it will turn out to be a simple thing once you find it .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() Last edited by VWNate1; 05-25-2023 at 10:20 AM. |
Re: Fouling plugs
Hard to get a good plug read 'just idling'. Drive it 20 or so miles to a good place to eat, get lunch, come back and when it cools off, see what the plugs say. Plus it will be a good start on the break in process.
#14 | |
Re: Fouling plugs
thanks
