08-19-2023, 02:24 PM | #1 |
door seals scientific data 55-59
Well maybe not scientific, but its my data I learned through my observation.
I installed the new soffseals door seals back in pre body work stage. I fought with it like everyone else, (could barley get the first door latch to catch) pushed the truck in and out of the garage for 6 months to let it sit out in the Florida summer heat. It did a little better. but still far from acceptable. so I Noticed that the lower corners of the doors (where the seals did a 90 degree where they bond the seals together) it was like a rock. I can only compress it maybe 1/16 of a inch. So I cut those out on each side, It was a tremendous difference, the doors closed great. But still a 1/4 inch from being flush with the cab. I cut the bottom off of the seals and it was 1/16" off. I then proceeded to split the jambs and brought them out so the door and cab was perfect. I moved on to the body work. I left the doors and seal and front fender and did all the body work as one panel ( came out laser straight) .NOW, fast forward after paint ,cut and polished . I installed NEW soffseals since the old one had body filler and primer all over them. After installed and shut the door of course I had all the same issue. So I cut the 90 corners out and helped out a bunch . I pushed the truck in and out into the sun for the past 4-5 months....helped a little but not much......so I found that cutting the whole seal out of the bottom and it was dead on. You can see in 2 pics below where i have the old seal and new seal side by side and you can see how much the old one shrinks over time. I hope this helps some folks for I would see post after post with this issue......as for the bottom seals . Steele rubber has a whole slew of universal seals, I will find one to fill that void and graff it in with the original seal Last edited by Rickysnickers; 08-20-2023 at 06:33 PM. Reason: n |
08-19-2023, 02:25 PM | #2 |
Re: door seals scientific data 55-59
add
08-28-2023, 08:27 PM | #3 |
First off, your doors look great. You can see the effort made getting the fitment just right. We got mine as close as they will be, without major door work. We did use Steele Rubber door seals, and they relaxed after a few weeks and close great (these are the original pics, and they have gotten even better). Definitely look at Steele Rubber for their universal seals so you can graft in material.
08-29-2023, 03:17 PM | #4 | |
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
08-29-2023, 05:30 PM | #5 |
