11-20-2023, 11:50 PM | #1 |
1970 Grille question.
What is the color/shade of the Silver that’s on the lead edge of the 70 Grille Insert?
Is it Argent Silver? |
11-20-2023, 11:57 PM | #2 |
Who Changed This?
Re: 1970 Grille question.
Is the insert metal or plastic? I believe both types exist. Mine's plastic (repro) and appears to be painted argent.
11-21-2023, 02:04 AM | #3 |
Mine is the factory original, and it’s plastic.
I think you’re right on the color being Argent Silver |
11-21-2023, 08:39 AM | #4 |
The only "silver" I'm aware of on factory built units are the horizontal raised bars that were "silver" or "argent".
When I get to that point on my 1970 Blazer's grille, I'm going to color the horizontal raised bars with this:
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 11-21-2023 at 08:45 AM. |
11-21-2023, 10:18 AM | #5 |
Those 2 pics (of the grill) you posted highlight the only thing that bugs me about replacement outer grills: Original - the horizontal lines continue to the headlight buckets. Replacement - the same lines stop at the parking light.
11-21-2023, 10:33 AM | #6 |
Was the 69 the same as this with the silver on the insert?
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
11-21-2023, 10:51 AM | #7 | |
For some reason not easily explained, GM discontinued outer grille 3980036 in favor of the slightly different 3985054, which is what the reproductions were patterned after. Its super easy to spot an assembly line used grille on these. The NOS grille going on my 1970 is an old one-box is dated June 1978, and unfortunately it is the second design that does not have the black extending all of the way to the satin black steel headlamp bezels/doors. Also a note on the satin black steel 1969-70 headlight bezels/doors. GM discontinued them very early on in favor for the bright aluminum bezels that were original equipment on all 1971-72 trucks/Blazers/Suburbans. I think the later aluminum bezels/doors look terrible on the 1969-1970's. 3937473 LH changed to 3990705 in 8/1971 3937474 RH changed to 3990706 in 12/1971
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
11-25-2023, 02:58 AM | #8 |
The replacement grill insert that I obtained years ago and you got from me is plastic like the original is entirely argent silver. It has the raised sections which I understand newer replacements do not (correct me if wrong). I am not sure which year 69 or 70 the grill was black with the raised sections in silver. With some time and patience you could mask off the raised sections and paint the rest black if you so desire.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 11-25-2023 at 03:08 AM. |
11-25-2023, 07:43 AM | #9 |
Sometime in the late 90's or early 00's, I obtained my 3985054 (thanks 1970cstblazer) outer grill and the replacement inner grill after some front end damage on the highway. Comprehensive coverage is a wonderful thing
The full grid section on that inner grill (3985056?) is also completely argent silver, with the surround being black. |
11-25-2023, 08:11 AM | #10 |
Most of the replacement 3985056 inner plastic grilles are painted totally wrong from GM. They have to be either stripped, or reshot, then paint the raised bars.
11-25-2023, 11:32 AM | #11 | |
Who Changed This?
11-24-2023, 10:39 PM | #12 |
On my grille, I repaired the black plastic, painted it black base coat, then used silver high performance silver metallic vinyl, cut into 1/8” strips, then shot a satin clear over the vinyl and base coat.
There didn’t seem to be a good way to get the silver consistent in paint. Ed |
03-11-2024, 09:02 AM | #13 |
GM never had a 70 replacement inner grill. All replacements are 69 inner grills. Thus they all came in th silverish color.
03-11-2024, 09:29 AM | #14 | |
GM # 3980037 changed to 3985056 in 8/1971. Before that GM # 3937301 changed to 3980037 in 7/1970.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 03-11-2024 at 09:37 AM. |
03-11-2024, 10:25 AM | #15 |
Doing more research on this, it appears that GM 3985056 are actually 1970 grilles painted like the 1969 grilles. Note the raised bars in this photo:
The assembly line 1969 grilles don't have those raised horizontal bars.
03-11-2024, 10:23 PM | #16 | |
I'm not sure how long Gm offered these but it must not have been long since they are so hard to find now. As far as aftermarket, I have only seen them offered with the whole center area silver. However, they have the raised areas like the 1970 oem inner grilles (but the raised areas are not 100 percent identical to the oem 1970 grilles). I don't think that the oem 1969 grilles had the raised areas (see this post by member FirstOwner69 regarding the oem 69 inner grille.) This has all been covered in various threads on the forum over the years. Here are some more examples of other NOS 1970 grilles. Last edited by cericd; 03-11-2024 at 10:56 PM. |
03-11-2024, 11:09 AM | #17 |
Thanks for info. That was stuff I got from a GM parts dept guy who is also into 67-72 trucks.
03-11-2024, 10:37 PM | #18 |
Here is a thread from 2020 in which member IronCanine illustrates the differences between an OEM 1970 iiner grille and an aftermarket 69/70 one and how he dealt with it on his beautiful 1970 Blazer restoration. His info starts at post #10 of the thread.
04-10-2024, 08:11 AM | #19 |
I just rebuilt the grille on my 1970 Blazer using NOS parts such as the parking lamp lenses, hood bumpers, headlamp doors, and outer grille shell. I reused the inner plastic grille, all bracketry, T3 headlamp bulbs, the parking lamp housings, and hood latch. I sourced the grille mounting fasteners from AMK Products.
I used the Molotow large tipped chrome pen for the raised bars, after refinishing the grille with Eastwood under hood black. The reproduction 3944896 and 9428882 1969-1970 grille retaining fasteners from AMK: https://www.amkproducts.com/bulk-fas...oduct_ID=15036 https://www.amkproducts.com/search-result/?ser=9428882
04-13-2024, 08:54 PM | #20 |
subd
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
