![]() Join Date: Jul 2015
73 K10 - what to do - blank slate
I'm picking up a 1973 K10 short bed this weekend. It has no engine or transmission, and I need to start planning somewhat on the drivetrain. Historically, I'm a numbers matching guy. However as this has nothing, I feel like I can do what I want. Basically, I want a truck I can take on or off-road and not worry about it much. Some thoughts:
Well, that's about it. I'm open to everyone's opinion here, as I know a lot of you have already done this and have a lot of experience when making different choices from stock. Thanks for the help. |
![]() Join Date: Jun 2012
Re: 73 K10 - what to do - blank slate
I think trying to get 18 mpg in a squarebody going to be tough but there are my suggestions.
Buy a crate 350 with roller cam for reliability. Find a good used quadrajet carb and have it rebuilt by a reputable builder. 700R4 trans since computers aren’t your thing and have it rebuilt with all the upgrades to make it last. You should be able to pick up a good core for a couple hundred dollars. (I personally hate 700r4’s but they can be built to last). You will never have good mpg with a 3 speed auto. Or If you don’t mind a manual nv4500. Np208 transfer case because they are plentiful/cheap and are fairly reliable. I think it will be hard to have an engine rebuilt cheaper than buying a crate engine unless you do the work yourself. Buy a crate engine from a reputable company that offers a warranty. I have a blueprint in my K20 and have been really pleased with it. Put 3.73 gears in it. With all that being said you might get 14 or 15 mpg. That’s just my thoughts! Sounds like a fun project.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
You might want to look for a 80’s 4x4 squarebody donor that has a bad engine. Then you would have most of what you need and then purchase the crate engine.
Check your tire size/gear ratio/transmission vs RPM with one of the on line RPM calculators. You don't want a combo where the OD RPM is too low. You don't want to find out after the fact that your gears are wrong for your $1000+ set of tires/rims and something has to change. Changing either at that point gets expensive.
More HP/torque often equals less MPG. A 'go fast' truck often goes through gas fast. Use the results from the RPM calculator to pick your cam/intake. A cam that works best at 3500+ probably won't give good results in a setup that spins at 2300 in overdrive. For a do it yourself motor, 350 + vortec heads + roller cam. If you go computer/injection, get one that include the ability to control an electronic trans. Several computerized overdrive trans options. But stand alone trans controllers can get expensive. If you go computer, might as well look for some variation of LS transplant. |
I would encourage you to embrace the digital age and go with an LS swap. The best way IMHO is to completely ignore the aftermarket. Get an LS and trans with < 250,000 miles and do not touch it (well ok you can replace a gasket only if it is visibly leaking). It was running when the truck was wrecked - it doesn't need to be gone thru, cleaned up, tinkered with, etc.
Just a reminder, the LS engine has been around since the 1990's. The average mechanic does not know how to work on a small block chevy. Much less adjust a carb. Get a run of the mil 5.3 with 4L60E from a 4x4 vehicle. The issue with transfer case can be solved by using a passenger drop 241C from an 87-90 chevy truck or suburban. Regarding cost - you could make this cost more than $10k by buying aftermarket stuff from JB conversions; Holley, etc, etc. Don't waste that money. There is nothing wrong with the stock parts. Use 100% GM factory stuff and it all bolts together and works. |
