![]() Join Date: Jan 2016
C50 power steering bracket
I’ve got a 1972 Chevy C50 with a Sb350 in it. All original. I need the bracket the PS tensioner bolts to. Mine is bent causing the pulley to be out of alignment.
Born Psycho
![]() Join Date: Feb 2001
Re: C50 power steering bracket
i'm not familiar with the bigger trucks but looking at your picture it looks like the bearing on the pulley is bad.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Born Psycho
i only know of one of those bigger trucks sitting around here but it has the 366 big block in it. i want the tach/vacuum cluster out of it but he won't budge on the price he wants for it-$200.00 and he doesn't know if everything works or not, i offered him $100.00 as is so i'll let him sit on it for a while and see if he changes his mind. yeah , i'm a cheap bast@rd
I pulled a bracket off of a 366 thinking it would work. It doesn’t but the tensioner is the same. So I’ve got a spare. Good luck with the cluster.
Born Psycho
we did the heads on this beast over 30 years ago as a winter time project at the shop where I still work-what a job getting those heavy SOBs out of the engine compartment. I tried getting that cluster way back then, one of these days maybe. good luck with your search for that bracket.
