03-04-2024, 11:03 AM | #1 |
Connector help
Any idea what this plugs into? It is in the transmission harness, But I can't seem to locate the other end
1965 C10 1967 Camaro 1998 C1500 2011 Colorado W/T |
03-05-2024, 02:03 PM | #2 |
Re: Connector help
Wire colors? Is it 4WD? Output speed sensor for 4WD lt blu, and Green/yellow.
It looks like the tail light connector, Green, brown, yellow, black.
'47 Panel to '88 K2500 Frame Swap Mechanical Speedometer Drive Solution 1947.2 1 ton Chevy Panel 1955.2 Chevy 6700 Bus/RV 1990 Chevy K1500 |
03-11-2024, 03:53 PM | #3 |
Re: Connector help
1998 c1500 2wd. Colors are hard to make out. Itis in the harness right above the transmission.
03-11-2024, 05:36 PM | #4 |
Re: Connector help
looks like an 02 sensor plug?
04-01-2024, 10:22 AM | #5 |
Re: Connector help
It turns out that it was not used. I am guessing it was for a transfer case. I noticed this as the plug has a dust cover that exposes the connections.
