#1 | ||
"I ain't nobody, dork."
Longer Wheel Studs
I have searched all over this forum, Google, Bing, Slummit Racing, Jeg's, Dorman...etc.
![]() This has to be the place to ask since all the drag truck cats MUST have longer studs to race. When I was racing a 1971 ElCamino SS back in the 90's, finding longer wheel studs for that rig was as easy as going down to the local parts store or tire shop and picking some up and pressing them in. I can't find any that are the length I want to come through the lug nut like in a racing application to be NHRA legal. I plan on making some passes in the truck once it's back up and running, so I will need longer wheel studs. I will be using stock discs (1972 GMC) up front and have Moser axles out back. I have old school ET 15x10 slot mags out back and will be running some sort of DOT radial drag tire. 15x7 ET slots up front. Where in the wide world of sports is a cat to find longer studs? ![]() Gary
Re: Longer Wheel Studs
Mr gasket 4310g are the only ones I have found. I have not used them.. But also need longer studs on my setup.
Project Roxy... Shes Bad, Low, and Blown... http://67-72chevytrucks.com/vboard/s...d.php?t=673333 |
#3 | ||
The stock lugs are 1/2"-20 with a .530 knurl. Those have a .480 knurl and are 7/16"-20. I don't mind switching to a smaller diameter stud with the correct knurl if that's what I have to do to get longer ones in there.
Gary
Moroso should have what your after. This is in the ballpark. Worse case you drill the holes slightly bigger. http://www.moroso.com/eb/catalog/nav...nuId=main.menu
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#5 | ||
That is exactly what I'm looking for. Guess I didn't broaden my search far enough. Granted I hadn't made any phone calls yet. But it just seemed like there was nothing really close to what I wanted in a 3" length stud.
Gary
You aint the first guy doing this. Moroso has a ton of the harder to find stuff especially for drag racing.
ARP makes some real nice stuff.
See if you find what you need here. http://arp-bolts.com/kits/Product.php?PL=55
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
#8 | |||
![]() Gary
#9 | |
#10 | ||
That is very unfortunate. Even a knuckledragger like myself... I am a product of technology and resort to phone orders only after I've exhausted all my online research.
I can remember calling in orders on the rotary phone in my dad's shop to P.A.W. or to the local speed shop. Then staying on the line with the sales rep for an hour BSing about cars and drag racing. ![]() Then there were "Super Shops"... I learned to avoid those places as the sales cats worked on commission. They pushed certain brand name parts and made you feel guilty about not using them. ![]() Gary
I used Moroso, they have 3 inch x 1/2 with the .520 knurl
![]() Join Date: Jun 2006
P.A.W. I remember that giant catalog that they had it was like three inch thick, I only bought tires from Super Shops after I found out about Jegs. I went to one of the P.A.W. warehouses in CA when I lived there and it was as big as the catalog, thanks for the memories.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#13 | ||
P.A.W. had all the rebuild kits in the front of their giant catalogs... "Super Gorilla 426 Small Block Chevy Performance Long Block Kit".
Always chuckled at the Super Gorilla description. Gary
I spent a ton of money at Super Shops back in the day.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#15 |
Does anybody have the Moroso part number?
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
#16 |
Does anybody know of a longer press in stud with .520 knurl?
#17 |
motor exploder
Moser carries a pretty good selection of studs too last I checked. I got a set from them last time I ordered axles.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#18 |
Moser only caries the stock length in that size.
#19 |
I too need longer studs and I researched for ever and could find a lot of 3" 1/2-20 studs but only one that had the correct knurl diameter. And I hated to buy them because they are $10 a piece. They are Baer brake studs part # 136-6280012 from jegs.
#20 |
Thank you for providing the part number. I've been searching all over.
http://www.jegs.com/i/Baer-Brake/136/6280012/10002/-1
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 05-23-2017 at 10:57 AM. |
#21 |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Resurrecting this zombie of a thread!
So I too needed longer wheel studs and I found this thread. Bought 10 of the 6280012 and 5 on one side pressed in beautifully and after I pressed out the factory studs on the other side, I went to press in the new studs and the hole in the flange was far to big for knurling. Ends up that I need 5 studs with .620 knurling which is 6280010. Somebody in the past history of that axle has either found another axle that fit during a replacement (which I doubt), drilled out the flange for .620 studs and pressed them in, or the factory ran out of .530 studs and switched over to .620. Either way, I’m now waiting on 5 more long studs from Jegs. The lesson here is don’t be like me and _measure_ what size of stud you will need before you order parts, my friends!
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#22 | |
Good thinking, I'm in need of longer studs also.
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 ![]() My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
