Junior Member
![]() Join Date: Jan 2010
68 misc parts
Frame is sold to a fellow boardmember. Motor, trans, everything else available.
I have a 1968 1/2 ton trailing arm sb roller frame for sale. Front disk brakes, pwr steering, manual brakes. No parking brake cables. Also included there is a 350/ 3sp column shift trans., the engine ran before parking, but probably needs work. Trans needs at least a rear seal but otherwise worked. No intake manifold/carb/air cleaner. M/T Thompson valve covers included. All other accessories complete, including ram horn ex. manifolds. I also have the 3 sp. column, steering wheel w/the usual cracks at joints, chevy horn buttons, and the clutch parts. Also have the radiator, heater core & in cab gas tank, fold down spring type seat, some broken springs,upholstery shot. Last edited by pops45; 09-27-2013 at 09:23 AM. Reason: added stuff |
![]() Join Date: Apr 2001
Re: 68 Short bed roller frame
Interested.
72 Cheyenne super swb 4x4 68 CST swb anniversary gold 67 custom swb 4x4 |
Junior Member
PM sent.
Pm received ill hit you up later.
GM Addicted
where at in sacramento are you located??
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
Junior Member
The frame is in Rancho Cordova. I'll be out of town this weekend, back home Sunday. The zip code is 95670.
Mo- are you still interested? Posted via Mobile Device |
Junior Member
Sunday bump.
pops, the deal fell through. i'll pass. thank you
Junior Member
Tuesday bump.
Junior Member
Ttt
PM sent.
Junior Member
PM replied to.
Junior Member
Bump.
Junior Member
Ttt
#15 |
Junior Member
68 misc parts
Still have:
350/ 3sp column shift trans., the engine ran before parking, but probably needs work. Trans needs at least a rear seal but otherwise worked. No intake manifold/carb/air cleaner. M/T Thompson valve covers included. All other accessories complete, including ram horn ex. manifolds. I also have the 3 sp. column, steering wheel w/the usual cracks at joints, chevy horn buttons, and the clutch parts. Also have the radiator, heater core & in cab gas tank, fold down spring type seat, some broken springs,upholstery shot. Last edited by pops45; 09-27-2013 at 01:50 PM. |
