Old 12-17-2017, 08:20 PM   #1
iglehart332
A/C Restore
Hi all,
Just wondering if someone could point me in the right direction. I have a 1984 C10 w/ a 1995 TBI 350 motor in it. As you can see it is missing some things for the A/C system. I am assuming the previous owner simply did not hook up the A/C after the motor swap. Now my question is, if the compressor is from the 95 motor will it work with my truck? Also are there any really good A/C threads videos or books?
Thanks,
Paul
iglehart332 is offline   Reply With Quote
Old 12-17-2017, 10:31 PM   #2
44th Miss Inf
Re: A/C Restore
I will try to remember to look in the morning when I get home from work, but I'm 99% sure my 89 Blazer has the R4 compressor mounted on the right side, same as your picture.
If so, you could order hoses etc for that model
44th Miss Inf is offline   Reply With Quote
Old 12-18-2017, 12:36 AM   #3
Man With A Gun
Man With A Gun's Avatar
Re: A/C Restore
Why do you have two fuel filters?
77 Chevy K20 Longbed
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Man With A Gun is offline   Reply With Quote
Old 12-18-2017, 07:17 PM   #4
hatzie
Moderator
hatzie's Avatar
Re: A/C Restore
If you look at the manuals thread in my signature there are several GM service training textbooks on GM A/C systems. The 1973 service manual has some excellent theory of operation info in a shorter format than the service training textbooks but the textbooks are very thorough. The 1984-1991 service manuals will have some specific information on your system. I scanned the 1995 service manuals as well so...
1995 should still have the same barely adequate Harrison R4 pancake compressor that your 1984 started its' life with. If it's on the same side of the engine as the 1984 compressor and clocked the same way you should be able to just use 1984 lines after replacing the flexible sections with R134A barrier hose.
You'll need to replace the accumulator/dryer and orifice valve with fresh units along with swapping all of the o-rings and gaskets in the system with R134A compatible stuff. Obviously you should unseal and install the new dryer dead last... just before you pull a hard vacuum on the system to keep the moisture contamination of the fresh new dessicant to a minimum.
You'll also need to replace or remove any mufflers in the hard lines if you're re-using them... note I'm not entirely sure GM used AC mufflers on the CK trucks in 1984. They did on the A6 on my 1976 so I'm just covering my bases here.
I would recommend emptying the compressor and changing the unknown pedigree compressor oil to Polyol Ester oil with UV leak detection dye. I would also thoroughly flush any hard parts you intend to re-use... hard lines, condenser, and evaporator etc to get rid of all the leftover Mineral oil bugs, dirt, etc that you can possibly flush out.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
a/c, air conditioner, air conditioning
