Old 05-07-2019, 11:51 PM   #1
kipps
Clutch pedal return spring?
My '87 has a broken torsion spring around the clutch pedal pivot shaft. Looking on LMCtruck, I don't see any mention of my style of spring. Instead, they show only an extension spring up through '84. I don't have the holes for the extension spring, but do have the notches for the torsion one.
Does anyone know where I could get a replacement torsion-style spring?
Thanks.
kipps is offline   Reply With Quote
Old 05-08-2019, 05:52 AM   #2
GM72K10
Next!
GM72K10's Avatar
Re: Clutch pedal return spring?
http://www.gmpartswiki.com/getpage?pageid=56386
Number 4 part number is gm 15592276, been discontinued for a while though
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 05-08-2019, 08:22 AM   #3
kipps
Thanks a lot for posting that site! I've been wishing for some access to GM parts diagrams for some time now. It's been pretty handy with tractors, to be able to go to the manufacturer's sites, look up the part I want, and google the part number. Until now, I've had no way to do that with my truck.
But yeah, it looks like no one is carrying this spring. I'll see if there's some way I can drill and adapt a common spring to fit instead.
I'll have to guess on how strong the spring was supposed to be. I'm assuming that on both the brake and the clutch pedal, the springs are only just strong enough to bring the pedal to the top of the stroke. Does this sound right?
Old 05-08-2019, 06:12 PM   #4
kipps
GM72K10, how do I go directly to a desired page? All I can do is go through them sequentially, starting at page 1. There do seem to be shortcuts to "front axle/steering", and "transmission/brakes."
I'm looking at the "52R" catalog from 1990, which seems to be the most applicable to my '87. Link below. Any assistance appreciated.
http://www.gmpartswiki.com/getpage?pageid=56090
Old 05-09-2019, 05:57 AM   #5
GM72K10
Next!
GM72K10's Avatar
I have the actual books themselves. There is an index in the front if that helps or google the part number for an equivalent. Good Luck.
86 K30 CUCV M1028A1
Old 05-09-2019, 10:33 AM   #6
kipps
I can sequentially "turn" the pages, and get to the index within the first couple. The problem is, if I want to get to page 985, I have to click the "next page" button 985 times.
How did you get to the page you linked above? It would take me an hour of clicking to reach it by my method.
Old 05-10-2019, 12:07 AM   #7
1774btcrew
1774btcrew's Avatar
I am looking for the same thing. I have one that did the same thing.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 05-10-2019, 09:42 AM   #8
sweetk30
sweetk30's Avatar
an idea that might work .
hydrobost brakes have a return spring on the brake pedal and have a tab that slides over the brake rod mount pin and then the spring hooks to it and to the hanger frame .
you might be able to use these parts to rig up a good return spring setup if no replacement springs are available.
also in my home town there is a spring company that makes TONS of springs from super tinny to big . they might be able to help i dont know . but they would prob want to see a good one to know the shape / size wire / tension used .
http://www.fennellspring.com/
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-10-2019, 10:19 AM   #9
SunSoaked
SunSoaked's Avatar
This.
SunSoaked is offline   Reply With Quote
Old 05-10-2019, 10:46 AM   #10
kipps
Sunsoaked, yes, that's the spring I'm referring to. I would love to replace the spring now, while the pedal is out of the truck. It seemed almost impossible to remove the pedal by itself, so I removed the steering column and then the complete pedal bracket. It could be if I looked at it longer, I could have gotten a wrench up to the pivot bolt.
Sweetk30, I looked about that, but it would involve a bit of welding to make it happen. The clutch pedal bracket doesn't wrap around enough to do a drop-in spring replacement. I am actually doing a hydroboost swap, so I do have that spring on the brake pedal.
Old 05-10-2019, 10:50 AM   #11
kipps
Another question. Is this the only spring involved on a hydraulic clutch? Is there supposed to be a spring on the clutch fork to pull the throwout bearing away from the pressure plate?
I know the mechanical-linkage clutches used a spring like that, but I haven't had one on my truck. It seems like it should be there, though.
Old 12-07-2019, 10:15 PM   #12
1774btcrew
1774btcrew's Avatar
Did you ever find a source for these? I can't find one anywhere!
Old 12-08-2019, 08:43 AM   #13
kipps
I did not find a source of new springs. I robbed one off a parts truck in a local junkyard.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
Old 12-08-2019, 10:30 AM   #14
1774btcrew
1774btcrew's Avatar
I am glad you found one. Is the truck still there? I could use the clutch pedal, bolt and 2 rods. I ended up with a pedal assembly someone decided to turn into an automatic
Old 09-26-2020, 07:26 PM   #15
1774btcrew
1774btcrew's Avatar
still looking for one of these
Old 09-29-2020, 10:50 AM   #16
blazer2007
I ,m sure I have some parts in the shed, I took mine out when I went auto. If you want them post a pic so I know what I,m looking for.
blazer2007 is offline   Reply With Quote
Old 09-29-2020, 10:51 AM   #17
1774btcrew
1774btcrew's Avatar
Awesome! I will PM you a picture
Old 10-06-2020, 02:34 PM   #18
1774btcrew
1774btcrew's Avatar
This is the spring I am looking for..sorry for the delay it took me a while to find it.
Old 10-20-2020, 10:18 AM   #19
1774btcrew
1774btcrew's Avatar
I posted a picture of the spring I am looking for.
Old 10-21-2020, 10:53 AM   #20
blazer2007
Sorry , the one I saved is from older type with the large spring that just pulls the pedal up like a big carb spring. Would that not work ?
Old 10-24-2020, 10:11 PM   #21
1774btcrew
1774btcrew's Avatar
Thanks for checking. That style won't work as there are no provisions to hook it to on a hydraulic pedal.
