Moderator
![]() Join Date: May 2007
Heater/AC question?
I noticed the other day when I was running the heater in my 03 that the AC compressor was cycling as if I was running the AC. Is this normal? I had the heater all the way up, recirculating off, and the “snowflake” button off as well. The air was warm, but I pulled the plug on the pressure switch by the dryer so the compressor wouldn’t run, and the air got a lot warmer of course.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: Heater/AC question?
Is there any chance that you also had defrost on?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Moderator
Pretty sure it was set to dash vents or floor, I don’t usually use defrost. I’ll plug it back in and rotate the dial settings to see if that has any effect on it. Thanks!
