11-07-2021, 06:04 PM | #1 |
low n' slo
dirty dingo mounts blocking ground bolt?
I'm either totally missing something here or do these dirty dingo mounts block the driver side ground bolt?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
11-07-2021, 10:04 PM | #2 |
Re: dirty dingo mounts blocking ground bolt?
Looks like it is. You should be able to use another threaded hole though. The one below it looks like it would work. I just found out today that a dirty dingo 4x4 front crossmember won't work with the factory brake lines.... You got off easy!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
11-07-2021, 10:43 PM | #3 |
Doesn't look like the engine is in the truck, do a radius clearance for it or use a ARP 12 point bolt or both?
11-07-2021, 11:58 PM | #4 |
Had problems with dirty dingo mounts years ago . And he was a real A-HOLE to deal with when i called him out on his crap quality control .
But as said ANY bolt hole will do for a ground point . There not super specific to just 1 spot .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-08-2021, 06:58 PM | #5 |
Yeah, I had the same issue, very disappointing that there was no communication of that problem.
____________________________________________ 1972 K20 Cheyanne 1956 VW Bug LQ4/4L80E Swap: https://67-72chevytrucks.com/vboard/...d.php?t=796095 |
11-08-2021, 06:59 PM | #6 |
I agree, I called a couple times when I was having some issues and not very friendly or helpful. Seems a few minor adjustments would make it much more user friendly.
11-08-2021, 08:26 PM | #7 |
a small radius cut will not effect the structural integrity of the mount. It will just make you life easier.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
11-08-2021, 10:19 PM | #8 |
low n' slo
ya there's no way this bolt goes on without taking a little chunk out of the mounts. I will use the bolt hole below that one. just weird that these don't already come clearanced around that ground bolt hole
11-08-2021, 11:53 PM | #9 |
Just to clarify my problem . His original slider mounts had welded on tabs . Once blasted in a cabinet before paint i found cold welds . He sent me a 2nd set . . Then same blast before paint and same cold welds . 1 was so bad i could stick a sheet of paper in the gap .
Not long after he offered to buy my silence off i saw he changed the design to a bent tab style . I told him his attitude and crap welds and wanting to by my silence was not good . . . So i still tell my story as it is and no b/s filler crap .
11-10-2021, 06:36 PM | #10 |
low n' slo
well the passenger side seems even worse. the motor mount hit the top bolt casting for the ac compressor
11-13-2021, 01:52 PM | #11 |
low n' slo
I really need to read the instructions...it does state to trim the passenger side motor mount at the bottom. glad I read it, I was about to grind away at the ac compressor mounting hole
