04-15-2022, 06:54 AM | #1 |
What are the other grilles for the 81-81?
I always liked the "billet" grilles you'd see on these trucks except for one thing: Nobody ever attached a chevy logo in the middle. They just left the grille blank, which didn't look as good. That got me to thinking, are there any other grilles for these old trucks? Maybe something aftermarket that was made for awhile? Any pics of grilles that aren't factory would be appreciated! I want to do something to set my 87 apart from the others. I was thinking of switching to the 1981 grille because I like it better. But first I wanted to check and see if there was anything else out there.
04-15-2022, 08:37 AM | #2 |
Re: What are the other grilles for the 81-81?
When I bought my truck, the PO had a Billet Grille with an emblem. But I didn’t like the Billet Grille, so I put together a stock grille and installed it. But here’s a pic of the Billet with the emblem.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
04-15-2022, 09:04 AM | #3 |
I didn't like the '81 grille when they changed the front end that year, but it grew on me as looking tougher. Also stands apart from later years same as 73/74 grilles. But the 81/82s are funky with single headlights. I remember people changing out to tube grilles but those were only made for dual headlights. You'd still have the 81/82 inserts under the headlights. Not very custom looking. Just remember, you'll need to do something for turn signal/running lights if you do that swap
04-15-2022, 10:24 AM | #4 |
If you want a different sort of aftermarket grille, and can find a way of fabricating your own, play around with vertical grille bars. Google pics of a 1969 Wagoneer for inspiration.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
04-17-2022, 01:48 AM | #5 |
Next question, if you had to buy a good quality replacement for your oem grille, where would you get it from? The one I'm using from ebay has cracked just from the stress of being mounted correctly. Apparently it can't even flex what little amount it has to from all the fasteners being on.
Side question: Does anyone know if this paint scheme was typical? So the white roof, combined with the white side. I thought if you had a roof that was a different color than the hood, you didn't get the roof color running down the side. I thought it was only on the bottom. Did they make some trucks like this? Or is this one a custom job that deviates from factory? White roof and a white side. Instead of white roof, white bottom. https://external-content.duckduckgo....6pid%3DApi&f=1 |
04-17-2022, 09:53 AM | #6 | |
Look through the vehicle information kits on gmheritagecenter.com for more info. https://www.gmheritagecenter.com/gm-...tion-kits.html
04-17-2022, 10:11 AM | #7 | |
Some pics from the web |
04-28-2022, 06:18 AM | #8 |
Thank you for the reply! But where specifically, is supposed to be 2" higher? Should the bottom brown part come up 2 more inches, or should the middle white part be up higher 2 more inches?
04-28-2022, 08:13 AM | #9 | |
The dual headlight truck has the 'dumbo' mirrors I'm referring to.
04-29-2022, 07:19 AM | #10 |
Wow yeah. Comparing those pics, the paint is really low on the truck I linked. Maybe they had to do that in order to have it look right. Maybe it would've looked bad with the white roof, if they didn't put some distance between the roof and the side stripe.
Wouldn't mind seeing them all so I could decide which one I actually liked better. If they're done well, most resto-mods still look great. |
04-29-2022, 10:55 AM | #11 |
Dual headlights whare available in any trim. My 81 k10 schottsdale dale has them. I've also seen Silverados with the big single light. It was just a box that was checked when ordering new. 83 up could aslo get the big single lights.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
04-29-2022, 10:57 AM | #12 | |
04-30-2022, 12:42 PM | #13 |
Good to know. I don't think I've ever run across that tidbit of information anywhere.
05-02-2022, 07:01 PM | #14 |
What exactly is the bumper filler?
05-08-2022, 09:26 AM | #15 |
The bumper filler is the body piece under the grille
While it's true dual headlamps was an option on lower trim levels, all Silverados came with dual headlamps
06-20-2022, 07:03 PM | #16 |
Do you happen to have a pic? I believe my truck may be missing this part. Not sure since I don't know exactly what it looks like. Maybe it's responsible for my grille breaking prematurely.
06-20-2022, 08:47 PM | #17 |
It only has original paint once |
