12-13-2015, 03:36 PM | #1 |
97 3500 454 4x4 project
I just picked up this 97 gmc 3500 454 4x4 yesterday. It's dirty, the bed is trash, but everything works except the air as far as I can tell and it's rust free. The front end will need a complete rebuild I'm certain. I'm planning on making this my daily driver, I live 3 miles from work thankfully, and use it when I go up to the farm. My ideas now are to go through it over the winter so I can depend on it. It's a dually now, but I want to change over to a fleetside bed when I'm finished. I only gave 1200 for it so as of now I'm happy with it. Anyone with ideas feel free to throw em at me. this will be a work truck, but I plan on it being a nice one.
76/77/78 Cheyenne 1997 K3500 454 soon to be 496 |
12-13-2015, 03:40 PM | #2 |
Re: 97 3500 454 4x4 project
12-13-2015, 03:42 PM | #3 |
12-13-2015, 03:45 PM | #4 |
12-13-2015, 03:48 PM | #5 |
12-13-2015, 03:51 PM | #6 |
12-13-2015, 04:02 PM | #7 |
Looks like a good starting point! I love the srw crew cabs the best!
12-26-2015, 02:58 PM | #8 |
Quick update. Started tearing down the front-end today and the pitman, idler arm, ball joints, and bushings are shot. The tie rods look ok, but there may be so much slop in the rest of the components it's hard to tell. Going to go back with moon everything.
02-13-2016, 04:58 PM | #9 |
02-13-2016, 05:08 PM | #10 |
76/77/78 Cheyenne 1997 K3500 454 soon to be 496 Last edited by mingoman; 02-13-2016 at 05:15 PM. |
02-13-2016, 05:13 PM | #11 |
My ball joint kit wasn't big enough to install the longer bushing so I had to use all thread to pull the bushings in. It worked. Hopefully I'll get the front end back together in the next few weeks then move to the interior.
02-15-2016, 02:53 PM | #12 |
Good looking project. I drive a 3500 w/454 for a daily as well, but 80+ miles a day. While you've got the front end torn apart, I would recommend a brake upgrade, it takes some parts scrounging, but it's sooooo worth it. My 7,400# truck stops WAY better. I've got it in my thread if you're curious, see signature.
When I did bushings & ball joints I had to get creative with the bench vise and the press to get everything seated/installed properly. The struggle is real when you work on fullsize stuff.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
02-15-2016, 05:05 PM | #13 | |
04-01-2016, 09:52 AM | #14 |
Here's before pic. I ended up changing everything except the drive axles and hub bearings though I gave the later a good shot of grease. Went with new rotors as well since the old ones are shot too.
04-02-2016, 01:12 PM | #15 |
Here's a pic with it together again. Took about two seconds to find my oil leak, I need new oil cooler lines, and I drained the front gear box today, going with synthetic.
04-07-2016, 03:23 AM | #16 |
looking good, i just replaced the front balljoints, tierods, wheel bearings, and suspension bushings in the front of my k3500... i feel your pain lol
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's 1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's |
04-11-2016, 09:01 PM | #17 |
Got the oil cooler lines changed out, oil changed, and stated on the doors. None of them opened from the inside and one wouldn't open at all. Got them all open and started cleaning year's of dirt off the panels. I picked up a bed that's behind them and a set of rims. I plan on getting those powder coated semi gloss black.
04-11-2016, 09:03 PM | #18 |
Here's an after shot of one I used a ton of soap water and elbow grease.
04-13-2016, 01:52 PM | #19 |
I'm on nights, but woke up and wanted to make sure of the lights I needed to change this over to led. I brought parts in to clean up in the house. Looked to have years of maybe tobacco spit covering everything.
04-13-2016, 03:06 PM | #20 |
Looking good, slowly getting it cleaned up and presentable.
I've gone so far as to strip everything seat/fixture/trim necessary to get the carpet out of a 1999 Suburban to hang up and pressure wash. Pressure washing worked great on the carpet too.
04-24-2016, 12:02 PM | #21 |
Still doing tons of cleaning. Found my dash had a crack under the grime so I went on a hunt for a replacement. Finally found one not cracked and my color though I'll most likely have to dye everything to match anyway.
05-03-2016, 08:11 PM | #22 |
Got the seats out and the old underwear that was stuffed behind them out as well today. Pulled it out for the first time since I brought it home too. The air should help!
76/77/78 Cheyenne 1997 K3500 454 soon to be 496 Last edited by mingoman; 05-03-2016 at 08:18 PM. |
05-03-2016, 08:14 PM | #23 |
Classic country is awesome! Classic speakers suck! The Hag will never sing me back home through this, they'll have to be upgraded.
05-03-2016, 08:17 PM | #24 |
The price tag on this baby just keeps going down!
05-04-2016, 09:57 AM | #25 |
grab the kenwood 1665's off of amazon. great speakers for the money.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
