12-28-2021, 05:27 PM | #1 |
350 engine
I have a stock 350 from a 69/70 c10, and want to build an engine for my 68 c30. Don't care about HP but would like to get all the torque out of it that I can.
What build s torque in a motor, do I have to put have a lot of hp to get torque, or should I just go with a big block engine?
Tom in Iowa 68 L88 C10 68 4x4 C10 soon |
12-28-2021, 06:04 PM | #2 |
Re: 350 engine
A basic recipe would be 185cc afr heads or equivalent. 110 lsa roller cam with 210/229 duratuon. Headers and a 3 barrel dual plane
12-28-2021, 07:04 PM | #3 | |
Re: 350 engine
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-28-2021, 08:06 PM | #4 |
Fabricate till you "puke"
Re: 350 engine
Bore it .030, then stroke it to 3.75 (383).....a good set of heads, & a mild cam will get you there longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-28-2021, 08:25 PM | #5 |
Re: 350 engine
Thread Tools | |
Display Modes | |
