Old 01-08-2007, 11:51 PM   #351
PBFAB.COM
PBFAB.COM's Avatar
Re: Dropmember in a 69 C10
Originally Posted by jlaird View Post
I just wanted to say thanks to nathan for taking time out of his day to help me out. I gave him a call today. Sounded like a stand up guy. I was just reading your updated parts list. We can use the 73-87 3" drop spindle, correct?
Correct, the 73-87 3" drop spindle can be used ( and necessary to lay it on the ground with a 29" diameter tire), I just don't offer it... yet. Keep in mind, the 73-87 spindle uses a different ball joint than the others.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-09-2007, 12:11 AM   #352
jlaird
jlaird's Avatar
I'm aware of the ball joint issue. Can the newer ball joint(73-87) be used on the 67-72 arms?
jlaird is offline   Reply With Quote
Old 01-09-2007, 12:20 AM   #353
dan468
dan468's Avatar
yes
dan468 is offline   Reply With Quote
Old 01-09-2007, 01:40 AM   #354
SCOTI
SCOTI's Avatar
My opinions on the rack and pinion... For my personal vehicle, I would install a manual rack. Dino's 66 SWB and 63 panel both have manual racks and are a pleasure to drive. The only real added benefit of Power Assist is that it makes life easier turning at low speeds. If you are running a smaller diameter steering wheel, a power unit will diminish the amount of profanity while attempting to park. A manual rack is an almost sure thing that your wife or girlfriend will never want to drive your truck!
Of course, if you are going to be running other ammenities, such as A/C, why not go power rack as well? The added cost is about $150.
My deal is I'm trying to minimize the 'hardware' under the hood. A pwr steering pump (even a small one), means the brackets for the accessories I must have (a/c, alt) will need to move up on the engine which defeats the purpose . . ..... unless of course I spend yet another $1500 on a Front-Runner or Tru-Trac serp set-up.
I guess I should say I'm trying to minimize the underhood hardware for minimal cash outlay. Homemade/modified aftermarket steel brackets are a heck of a lot cheaper & already in place. The C4 Dropmember was appealing 'cause it would help shed some of those extra pounds that big ole' engine has vs something much smaller. I'm already doing alum heads, radiator, & electric fan/shroud combo to help minimize the front end weight.
How much drop is the dropmember? I mean, if I were to 'Z' the stock frame, how much would it take to equal the dropmember?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-09-2007, 10:23 AM   #355
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
I have some updated pricing on the Dropmember and its options. These are Board Member pricing only. One small change in relation to board member discounts: The board discount will be available to SUPPORTING Board Members only as of Feb. 1st (well worth the $25 fee to support the board).
These prices do not include shipping costs.
Dropmember 'Basic Kit' $1290, includes the following:
-Main cross-member
-Inner frame plates
-Upper control arm/ bag mounts
-Motor mounts (SBC 350... BBC and LS1 coming soon)
-Trans crossmember
-Rack and pinion mounting bushings
-Tie-rod ends and tie rod adjuster/adapter sleeves
-Rack and pinion tie-rod notch
-All hardware to install Dropmember
Additional options and pricing (these items will be needed to complete installation… you may already have some of these items).
-Steering linkage (shaft, joints, and idler) $243
-Rack and pinion $225 (power), $207 (manual)
-Power steering lines $90
-Air Ride Tech. 'Strong Arms' $674.10 (tubular control arms are not necessary, but recommended. The Dropmember was designed to be used with Air Ride Technologies' Strong Arms. Stock arms can be used with slight trimming on lower control arm).
-Air Bags (Slam Specialties RE7) $150
-Shocks (Monroe) $105.05
-60-72 6-lug rotor kit (rotors, calipers, lines, bearings, pads, seals, dust caps) $365.31
-60-72 5-lug rotor kit (rotors, calipers, lines, bearings, pads, seals, dust caps) $348.98
-2.5" Drop Spindles (63-70) $304.08
-2.5" Drop Spindles (71-72… must use 'heavy duty' rotors) $304.08
-2" Drop Spindles (73-87) $295.66
just wanted to know how much will you charge to install a complete system, labor and etc. bumper to bumper?
shaneo2112RUSH is offline   Reply With Quote
Old 01-09-2007, 11:49 AM   #356
PBFAB.COM
PBFAB.COM's Avatar
What is the starting point? Runnung driver? All sheetmetal? The starting point of the vehicle will have a large effect on the price. I charge by the hour, but can give a sound estimate.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-09-2007, 03:32 PM   #357
XXL
Señor Member
XXL's Avatar
Talk about a hijack...
SCOTI, I thought about running the alternator off of the rearend to get it out from under the hood. If you put the (right size) pulley on the rearend at the driveshaft and then mount the alternator back there, it might work pretty well... so long as you didn't spend a lot of time sitting at idle. Waddaya think?
XXL is offline   Reply With Quote
Old 01-09-2007, 03:34 PM   #358
XXL
Señor Member
XXL's Avatar
Any chance? I've got several projects I'd love some quality help on...
Old 01-09-2007, 03:41 PM   #359
dan468
dan468's Avatar
I can't remember what the brackets look like but boats w/ V-drive run the alt of the driveshaft. If you know anyone that has one it's a good place to start
Old 01-09-2007, 04:01 PM   #360
PBFAB.COM
PBFAB.COM's Avatar
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-09-2007, 04:13 PM   #361
XXL
Señor Member
XXL's Avatar
I was kind of thinking the rate was a little more than that. But... gotta ask
Old 01-09-2007, 04:18 PM   #362
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
so any update on the 69 C-10?
this thread on well on it's way to be the next million post thread :-)
IvelDesigns is offline   Reply With Quote
Old 01-09-2007, 09:52 PM   #363
SCOTI
SCOTI's Avatar
I've considered this option. But.... fuel injection, electric fans, a/c, pwr windows, stereo, air-compressors & ignition system make me think I want something that charges regardless of my mph.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-09-2007, 10:08 PM   #364
jimmydean
jimmydean's Avatar
Nathan, congrats on the article. I just got my issue in the mail today and it made me think about the difference in price between the dropmember and the C4 version.
Minus the price difference between bags/shockwaves, is there a price difference from a complete C4 dropmember spindle to spindle to the dropmember using strong arms and 6 lug discs?
I know you have a "source" for the C4 parts and your a dealer for Air Ride. But I dig the idea of the C4 kit. I'm not looking to lay frame, but to use Vette parts (I will have an LSx motor some day) would be so pimptastic!
<edit> NEVER MIND. I used search and found the info in the C4 thread. I still want it though!
jimmydean is offline   Reply With Quote
Old 01-09-2007, 10:21 PM   #365
watahyahknow
watahyahknow's Avatar
i've seen a show here once bout fomula one racing they got onboard power from a small generator powered by a model airplane motor .
might be too small for youre use but you could run a lil bigger weedwackerpowered dynamo generator under the bed if the driveshaft one doesnt provide enough juice (think i need to take my pill now )
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 01-09-2007, 10:21 PM   #366
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
did you just say pimptastic???? hehehe
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 01-09-2007, 10:34 PM   #367
jimmydean
jimmydean's Avatar
Dude, you can not tell me that by running an after market Vette suspension and steering setup wouldn't increase my pimp-factor by at least +5.
Of course I would end up spending way more than my initial budget, but I guess that went out the window a long time ago.
Old 01-09-2007, 10:47 PM   #368
jimmydean
jimmydean's Avatar
DropmemberC4 = $1200
C4 front kit off ebay = $800
Shockwaves = $850
Pimp-factor = priceless...
I'll be posting some internal organs on ebay this week. I need to support my habit somehow.
Old 01-09-2007, 10:55 PM   #369
PBFAB.COM
PBFAB.COM's Avatar
Scoti-
Just convert all your power to AC and run a Honda gas generator in back.. under the tonneau cover of course!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-09-2007, 11:02 PM   #370
PBFAB.COM
PBFAB.COM's Avatar
The 'Pimp factor increase" has been measured as high as +8.37 with this conversion...
Here's some pics of one going into a 71 Blazer... the body has a 'little' rust.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-09-2007, 11:10 PM   #371
gringoloco
A guy with a truck
gringoloco's Avatar
Beautimus!!!!! Anyone want to buy my first-born?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
Last edited by gringoloco; 01-10-2007 at 01:27 AM. Reason: I'm a non-spelling fu#*tard
gringoloco is offline   Reply With Quote
Old 01-09-2007, 11:16 PM   #372
XXL
Señor Member
XXL's Avatar
Originally Posted by gringoloco View Post
Beauitmus!!!!! Anyone want to buy my first-born?
Good luck! I've been trying to sell mine for 10 years... why do you think my truck is taking so long to finish?
Old 01-09-2007, 11:18 PM   #373
Col Clank
I really want one of those just can't afford it right now.
Col Clank is offline   Reply With Quote
Old 01-09-2007, 11:30 PM   #374
XXL
Señor Member
XXL's Avatar
Scoti-
Tonneau cover...
Old 01-10-2007, 12:18 AM   #375
SCOTI
SCOTI's Avatar
Ok.... we now return to our normal programming.
Nathan, in the barrage of posts recently I didn't see an answer to my question: How much drop is the dropmember? I mean, if one were to 'Z' their stock frame, how much would it take to equal the dropmember?
That C4 set-up sure looks right . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
