#101 |
Re: Dropmember Rear 63-72 Spy Pic
Dont think it was me, Truck has not been out for a while. I think its going back under the knife soon.
1964 CHEVY LB, 20" WHEELS, BAGGED ![]() |
#102 |
Looks good man, love the drop member you made for these guys a while back. Next time you do a write up on let me know i will send some of our arms , you can give them a try.
Richie |
#103 |
Linky linky . . ......
#104 |
would love to, but i dont want to piss any one off before i pay for the advertising. They are on our online store page and our myspace though. lol i am sure they will send me all the info to advertise tonight, then i can post pics and ****. Richie |
#105 |
Ok guys... Here's the updated pics of the production Dropmember Rear.
- Bolt-in notch with integrated bridge (available to lay frame from 26" to 32" tire diameters; designed for a 5" ride height) -Sleeved bags mounted over the axle for increased stability and ride quality. - Bolt-on arallel four-link with panhard bar (axle plunges .625" from ride height to dump; axle shifts lateraly .375 inches from ride height to dump) -Carrier bearing crossmember (allows the use of two-piece drive-shaft, eliminating cab tunneling)
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#106 |
One day...
Sweet man that looks good!
#107 |
![]() Join Date: Aug 2006
Beautiful!!!!! You know if you came out with this a long time ago you could have saved me alot of time, money and a hell of alot less stress.
![]() ![]() Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
#108 |
I've got a question about that carrier bearing x-member. The stock xmember bolts(rivets if you havent taken it off) to the top and bottom rails with (off the top of my head) about 20 bolts, and also has a reinforcing plate for the bottom rail. Your xmember bolts to the side rails with a total of 4 bolts. Are we losing any rigidity of the frame because the top and bottom rails are not tied together? Seems like the frame would twist a lot more especially since the closest xmember behind it is at the bridge.
Also, will that carrier bearing fit the stock driveshaft? If so, where did it come from. Thanks nate, Josh |
#109 | |
The chassis pictured had the factory trailing arm crossmember removed. There will be a crossmember to replace the factory trailing arm crossmember installed when the chassis is complete. This carrier bearing crossmember is designed to be used in conjunction with a modified factory trailing arm crossmember, or an ECE drop trailing arm crossmember. The carrier bearing is a factory replacement for a 71-72 LWB C10 truck.
#110 |
A guy with a truck
Swanky! What mods would need to be done to a stock t-arm crossmember? Flatten the bottom? Are the axle brackets weld-on?
Looks ![]()
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#111 | |
Currenlty the design features a bracket that welds to the axle tube and then the rest of the pieces bolt to it. That is the only piece of the entire kit that needs to be welded upon installation.
#112 |
PorterBuilt Man Crush
![]() Join Date: Jul 2007
Ahhhh...Sh**, you are getting worse than the IPHONE
The 72 will live again Last edited by jasonb72; 08-13-2008 at 12:48 AM. |
#113 |
Will the empire drive line billet carrier bearing work on the crossmember?
The 72 will live again |
#114 | |
The carrier bearing crossmember can be moved up,down, forward or back to accomodate different configurations.
#115 | |
#116 | |
A guy with a truck
I'm lookin' for a part time job... ![]()
#117 |
chevy only
![]() Join Date: Sep 2006
nice work nate,might have home for one soon
CHEVY ONLY... Nothin Else ! Last edited by Dinos63; 08-13-2008 at 10:19 AM. |
#118 |
I hope you felt the love.
#119 |
It's nice to know there's so many "man crushes" on this forum.
#120 |
Just wondering are you going to sell the 4-link separate from notch if someone wanted?
#121 |
I will offer it seperately (don't have a price yet), but the axle brackets would be a different design. They would be a standard weld-on bracket.
#122 |
Junior Member
Nate..... whats up brother!?!.... what rear airspring are you setting that thing up to use?
#123 |
cool thanks....brother
#124 |
F9000.... of course!
#125 |
Junior Member
![]() Join Date: Jan 2005
So this kit now is designed specifically to work with a 4 link and not with the factory trailing arms, correct?
-Andy |
