Old 08-20-2009, 12:21 PM   #76
mal68ibu
Parts Hunter
mal68ibu's Avatar
Re: Project 67 GMC custom 6.5 turbo diesel
djw32,
All the accessories are on the motor in one of the last pics I posted. They are the stock items that came on the motor (93 3500HD pick up). I had just lost some of the bolts so I didn't have the fan and belt on the engine yet.
ADam
1968 Chevelle 300 DLX (350 4 speed)
1984 GMC 2500 6.2, 700r4 work truck
1967 GMC Custom (was 6.5 Turbo Diesel powered)
My ebay Store: http://stores.ebay.com/The-Musclecar...3aFQ3aSTQQtZkm
My website:http://themusclecarshop.net/
1967 GMC 6.5 TD conversion build:http://67-72chevytrucks.com/vboard/s...d.php?t=290922
mal68ibu is offline   Reply With Quote
Old 08-20-2009, 05:24 PM   #77
70rs/ss
70rs/ss's Avatar
This 6.5 swap is looking more like what I need to do to my sub, as a Cummins swap is going to be hard and $$$. Besides I want MPG more than hp, but tq is always a good thing!! This post has me thinking I can do a 6.5 and have all I want and do it reasonable! More picts!!
70rs/ss is offline   Reply With Quote
Old 08-20-2009, 05:37 PM   #78
67cheby
67cheby
67cheby's Avatar
hey not meaning to change the subject but is the vw for sale
67cheby is offline   Reply With Quote
Old 08-21-2009, 11:18 PM   #79
mal68ibu
Parts Hunter
mal68ibu's Avatar
You mean that stinky POS that used to be parked next to my jewel? Its gone. I think the owner sold it. Not my taste so I didn't blink twice at it.
Old 08-21-2009, 11:40 PM   #80
mal68ibu
Parts Hunter
mal68ibu's Avatar
Spent the day tweakin the injection pump and applying sheet metal. Even took a video of it running and reving. Otherwise I spent most of my time drinking beers. Heres some pics. #$^&#$^&#$% my computer tonight. Pics later
Old 08-22-2009, 12:14 AM   #81
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Cant wait to see the pics of this bad beast up and running..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-22-2009, 11:00 AM   #82
mal68ibu
Parts Hunter
mal68ibu's Avatar
Alright so here are the pics I could not get loaded up last night. The front clip is going back together fairly easily. I had to clearance the hood release handle, and I'm not sure that will will as it is. I also had to clearance the lower part that bolts to the bottom of the grill to go around the intercooler lower mounts that are welded to the core. The intercooler fits just about perfectly behind the grill. I have to rotate the clamps for the pipes as they rest right on the grill. That duramax fan pulls a crazy amount of air at idle, and it sounds good. The last pic is of the switches to swap from diesel to veggie oil, and my glow plug switch. Those still need to be rewired. The brakes are all plumbed. I have a bracket to hold the residual pressure valves and one to hold the adjustable prop valve for the rear brakes.
Old 08-22-2009, 11:07 AM   #83
mal68ibu
Parts Hunter
mal68ibu's Avatar
I had one last pic. I also have a video but cannot figure out how to post it here. I've posted it on youtube and here is a link.
Old 08-22-2009, 01:41 PM   #84
6772owner
Gearhead
6772owner's Avatar
Looks like it is coming along well, keep it up, want to see the finished product soon. Sounds good!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 08-22-2009, 06:22 PM   #85
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
SWEET !!!!
I can wait to see more
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 08-22-2009, 08:22 PM   #86
FRENCHBLUE72
PROJECT 7DEUCE
Very cool she sounds great..
MEMBER #6377
Project "7DEUCE"
Old 08-26-2009, 12:36 PM   #87
mal68ibu
Parts Hunter
mal68ibu's Avatar
Cleaned up under hood wiring, finished bolting and ligning up the front clip (less hood and inner fenders), and wired up the dash switches to control the glow plugs and fuel system. I only need to wire up the two fuel level sending units and the electrical will be done. They will be run off the same switch that controls the fuel pumps. When the veggie pump is on it will read that side of the tank, and when the diesel pump is on it will read that side of the tank. The switch for the glow plugs is a one way non locking switch so as soon as I take my finger off of it, it shuts the glow plugs off.
Old 08-26-2009, 09:28 PM   #88
mal68ibu
Parts Hunter
mal68ibu's Avatar
MAIDEN VOYAGE WAS TODAY. It drove pretty well but I need to mess with the vacuum to the th400 as it just shifts to final drive really quick. I shifted it manually and it HAULS THE MAIL!! Its got a slightly rough spot so the timing is not spot on. I also have to fix a power steering leak now. All my wiring works properly and the stock fuel gauge works with the switch and sending units. The rings seated a little better today so there is a lot less smoke. IT SOUNDS SICK when you get into it. I can't wait to get all the **** out of the bed so I can really drive it. I will say that the hydro boost feels strange and so far the throttle response feels odd to me, but this is my first diesel and first truck with hydro boost. I'll probably have a vid of it driving next week.
Old 09-06-2009, 02:56 AM   #89
mal68ibu
Parts Hunter
mal68ibu's Avatar
I got the drivers side of the engine compartment fairly finished up. I had to massage the inner a little to clear the air intake piping. I made a little bracket for the engine oil cooler hoses. I had to relocate the wiring and I'll clean that up before I'm done. I installed my engine temp and oil pressure gauges just to find out my oil pressure gauge needs to be replaced. I have another pod on top of the dash with a vacuum gauge in it and a hole for the boost gauge when it shows up. More on that later. Trans still does not shift right so I'm hoping that I just have to fiddle with the throttle position sensor a little more, or dink around with the vacuum pump......you know the easy stuff. I did a couple laps around the block and the temp got up to 195 and just stayed there. It was 100 degrees out. Once the truck warmed up I got very little black smoke and it felt strong.
Old 09-06-2009, 03:39 AM   #90
barthmonster
Awesome thread ! Subscribed !
barthmonster is offline   Reply With Quote
Old 09-14-2009, 01:06 AM   #91
wildwilly4x4
I just put a 6.5 turbo into my 72 long/short box conversion 4x4. I plan on mounting my NV 4500 behind it though, for OD. I ended up using the entire engine crossmember(had to hack it all up to fit) out of the '86 military truck that I originally had this motor in. Looks like your project came out really good.
wildwilly4x4 is offline   Reply With Quote
Old 09-21-2009, 11:48 AM   #92
mal68ibu
Parts Hunter
mal68ibu's Avatar
Right now I must say that I really wish I had a NV4500. I'm pulling my hair out trying to get my th400 to shift. I had to replace the throttle position sensor (regulates vacuum down to the trans to mimic a gas motor), and I've adjusted it everywhere and the trans still wont shift right. Trans mind you only has about 2K on a rebuild, and has never towed anything. I have a few things left to check out before I throw the towel in and bolt up the NV3500 and hope for the best. However I did get the interior decked out. Covered the entire floor in sound deadener, and heat resistant stuff on the passenger side where the exhaust will be. New Carpet, and I found a good seat at my local junk yard that got a new cheapo seat cover, and restored 67 gmc lap and shoulder belts. No center belt because I was planning on restoring the buckets I pulled from a 69 and using those until the wife told me it needs to be a 3 seater for a little while. LAME!!
Old 09-21-2009, 11:50 AM   #93
mal68ibu
Parts Hunter
mal68ibu's Avatar
What are you going to run for clutch linkage? or will you go with hydraulic clutch? My NV3500 is my back up if I can't get the th400 to work.
Old 09-26-2009, 03:02 AM   #94
mal68ibu
Parts Hunter
mal68ibu's Avatar
We just finished off a sick exhaust system for the truck a couple hours ago. Took it to the local watering hole for a celebratory beverage. I found out through process of elimination that my vacuum modulator on the trans took a dump on me while hanging out doing nothing. Replaced that and the thing shift pretty good. I think I have some tuning to do as it shift to second really quick and takes a while (imo) to get into third. But between the adjustable vacuum mod. and the VRV on the IP I should be able to tune it quite a bit. The exhaust is LOUD!! I also need to do somthing about the crank case vapor and all the holes in the firewall, that I'm not using now. I should also have my boost gauge so I can see whats going on there, by monday, and later this week I should have the truck over to the tuner to make sure I have the IP in the right spot. The quick report now that the trans shift just about right is that the truck hauls the mail. My diesel buddy drove it tonight for the first time and just said wow. 1/4 throttle is more than enough around town. If I can keep my brain cells rolling in the right lane I'll pack my camera and get some more video of it moving.
Old 09-26-2009, 06:00 PM   #95
wildwilly4x4
I posted my build in the 67-72 truck forum. I am using a '91 model clutch master, and the internal slave thats on the '97 nv4500. I just drilled a hole directly off the clutch pedal and gave the master cylinder a home just to the drivers side of the hydroboost. I had it all working fine, until the used slave cylinder decided to start leaking, now I have to pull the tranny and mucho heavy np205 back out just to change it. I guess that will teach me to try and be cheap and reuse unknown condition parts..lol
Old 09-27-2009, 09:43 PM   #96
ERASER5
ERASER5's Avatar
You said residual valve[U]s[U]. Do you still have front drum brakes? If so, then your golden, but if you have disc brakes, you do not need nor want a front residual valve.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-28-2009, 01:53 PM   #97
mal68ibu
Parts Hunter
mal68ibu's Avatar
I ended up using two residual valves as pictured. The brakes are awsome. I really need to get a boost gauge on this thing, and a waste gate. Found out yesterday on a drive that I didn't tighten the oil return from the turbo, and oiled down my exhaust, so everything is a good ol mess under the hood now. I just got all the crap out of the bed of the truck so I can mess around with it and dial in the adjustable prop valve.
Old 09-28-2009, 06:05 PM   #98
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sinister
Killer
Old 09-29-2009, 11:41 PM   #99
mal68ibu
Parts Hunter
mal68ibu's Avatar
Originally Posted by Spray-Bomb View Post
Give me a break, nobody needs to see pics of nasty diesel oil sprayed all over the underhood. I'm still shaking it down. Let me post the nice pics.
Old 09-30-2009, 01:48 AM   #100
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
I'm in love.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
