Old 11-28-2009, 05:26 PM   #1
Butcherboy
Butcherboy's Avatar
Question Wire Diagram for 01' 5.3 Vortec engine swap
Hello, Just asking if anyone Has ever built/reworked there own engine wire harness for the LS 5.3 vortec? Id like to try this myself, I have the stock harness and ECM. I will be using a After market chassis harness. The engine is in my 89' S-10 blazer. Current performance might be the one to do this for me, but I would rather save the money and do this at home.
I will still need the ECM burned and programed. If anyone has a over view diagram that shows the color of the needed wires for the engine functions and controls. I can take from there! I have done some marine wiring in the past, and feel I can tackle this!
Any help with this would be great!
Thank you guys!
Justin Kansas
Butcherboy is offline   Reply With Quote
Old 11-28-2009, 08:21 PM   #2
clinebarger
Re: Wire Diagram for 01' 5.3 Vortec engine swap
Blue connector.
clinebarger is offline   Reply With Quote
Old 11-28-2009, 08:24 PM   #3
clinebarger
Red connector
Old 11-28-2009, 08:30 PM   #4
clinebarger
Data Link Connector
Old 11-28-2009, 09:27 PM   #5
Thealien
Thealien's Avatar
LOTS OF USEFULL INFORMATION HERE
Old 11-30-2009, 11:39 AM   #6
Butcherboy
Butcherboy's Avatar
Talking Re: Wire Diagram for 01' 5.3 Vortec engine swap
Thank you very Much!!! Exactly what I was NEEDING!!!
Next Question.
What are the wires not needed?
You guys rock!!
Justin
Old 11-30-2009, 12:41 PM   #7
Thealien
Thealien's Avatar
Next Question.
You guys rock!!
Justin
If you look through the link I provided he actually has a page showing what wires need to be fed with a fuse/relay, which are not needed to run with pictures and everything. Spend some time clicking all his various links
Old 11-30-2009, 12:44 PM   #8
Thealien
Thealien's Avatar
START HERE
99-02 HARNESS INFO
03-07 HARNESS INFO
Old 11-30-2009, 01:13 PM   #9
Butcherboy
Butcherboy's Avatar
Thumbs up Re: Wire Diagram for 01' 5.3 Vortec engine swap
Thanks! Just what I needed. Think I have all the info I need!!! Again Thank you!! I'll let ya know how it turns out!!
Justin
Old 12-07-2009, 12:48 PM   #10
Butcherboy
Butcherboy's Avatar
Started On the harness. Have everything except the relay and fuse box finished. Im gonna cheat and buy the relay box from Current Performance. Help speed things up! Thanks again for the info guys, started out good and wasn't as serious as I thought. Lots of reading and testing with the volt meter. Should have it done this week.
I forgot to tell you what my harness looked like when I bought this engine. The Jackass at the pick and pull cut the under hood relay and fuse pin connector under the hood. So no reference to go at, just had to beep test all the pink wires and label the injectors! LOL! I might just start doing harnesses after this little adventure, that's if things work!!
Before:
After:
Justin
Old 12-09-2009, 03:04 PM   #11
LEEVON
LEEVON's Avatar
Hey Justin,
Would you consider doing a write-up or FAQ or was the info from LT1swaps sufficient?
If I still feel retarded then maybe I am and I could be your 1st customer?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-09-2009, 03:17 PM   #12
Butcherboy
Butcherboy's Avatar
Originally Posted by LEEVON View Post
Hey Justin,
Would you consider doing a write-up or FAQ?
If I still feel retarded and unable then maybe I am and I could be your 1st customer?
LOL! Im still getting mine reloomed. When I have everything done and tested, Hell ya for sure start a thread!
Just changed the injectors to LS1 style, and traced all the grounds and other uneeded wires. The LT1 site helped alot. Pictures helped, but the amp meter was the saving grace. Id be glad to help you when Im finished.
The hard part is next, the lay out for the engine. The truck intake is taller, so the ls1 is short. Just got damm cold here this week. I don't have a heated shop. Maybe if my relay box shows up, Ill have it hooked up on the block and then shorten or lenghten my wires. The Vortec harness was a Rats nest from hell! But fo the most part, Im heading in the right direction!
Keep ya posted!
Justin
Old 12-11-2009, 04:42 PM   #13
70 Suburban
Rods
THANKS FOR ASKING THE QUESTIONS SO i DIDNT HAVE TO....LET US KNOW HOW IT GOES
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 12-11-2009, 06:10 PM   #14
Thealien
Thealien's Avatar
Glad its working out for you
Old 12-11-2009, 06:33 PM   #15
70 Suburban
Rods
i DO NEED 2008 5.3 (TRUCK) DIAGRAMS THOUGH
Old 12-11-2009, 06:42 PM   #16
Thealien
Thealien's Avatar
TRY HERE
HERE
AND HERE
You should be able to find help at one of theose locations!!
Old 12-11-2009, 07:01 PM   #17
70 Suburban
Rods
THANKS. i AM HOPING TO GET THIS DONE BY THE FIRST OF THE YEAR.
Old 12-11-2009, 07:09 PM   #18
70 Suburban
Rods
Did you say that you did ecm flashing... Or do you have the software
Old 12-11-2009, 08:25 PM   #19
Thealien
Thealien's Avatar
Sorry I do not. There are many that do from about$150-300+ and some lock their tune so nobody but them can change it.
Old 12-11-2009, 08:43 PM   #20
70 Suburban
Rods
yeah thats why i want the software so i can do what I need to do and change what I man need to change
Old 12-12-2009, 07:08 AM   #21
Thealien
Thealien's Avatar
The software from what I have seen is pretty expensive $500+ and there is a learning curve for using it. I am going in so many directions with my swap I am paying someone to do my harness and tune. If I do another I will do my own harness. I will probably always have someone else do the tune unless I find a great deal on the software.
Old 12-12-2009, 10:41 AM   #22
70 Suburban
Rods
Thats true. I have tuned stanalone units ie haltech. motec. but never realy messed with stock ecu's. I would like to play with the software a bit to see what can be done.
Old 01-02-2010, 04:55 PM   #23
Butcherboy
Butcherboy's Avatar
Post Re: Wire Diagram for 01' 5.3 Vortec engine swap
I have it Finished! Alot of work! Im not going to do this for living for sure! Too much to deal with, and would hate to have something happen to make some mad! Just gonna do this for myself and give the little info to anyone I can!
Justin
Old 01-02-2010, 06:01 PM   #24
Thealien
Thealien's Avatar
nice job! Keep us updated
Old 02-11-2010, 06:54 PM   #25
Butcherboy
Butcherboy's Avatar
Wink Re: Wire Diagram for 01' 5.3 Vortec engine swap
Thanks for the help Thealien. Im hooking things up this weekend. I bought a new chassis harness and scraped the stock wiring. I should have things wrapped up soon, that's if the weather holds! More parts came today! I just need to get after it!LOL!
Justin
