Old 03-13-2010, 05:19 PM   #1
LEEVON
LEEVON's Avatar
Should I get an extra frame?
I've got a complete '50 truck but I am a big fan of efficiency (lazy) and space is limited with a 3 car garage. There is an extra frame locally for next to nothing, I was thinking about bringing it home and starting with it first. I wouldn't have to have a truck blown all apart in my garage and yard and when the frame is done I could just swap the body over. Plus I'm sure the frame would fit in the garage now. Anybody done this? What are the advantages/disadvantages?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-13-2010, 06:04 PM   #2
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
Re: Should I get an extra frame?
Advantage: Easy restoration like you stated.
Disadvantage: Frame and body VIN numbers won't match.
addicted2dunes is offline   Reply With Quote
Old 03-13-2010, 06:21 PM   #3
LEEVON
LEEVON's Avatar
I'm not sure there are any #'s on the AD frames?
Old 03-13-2010, 07:08 PM   #4
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
I'd do the extra frame!
ChuckDriver is offline   Reply With Quote
Old 03-13-2010, 07:43 PM   #5
63 & 64 Bowties
and a few others
Does that frame still have the front axle on it? They're worth a few dollars to anyone building a fenderless rat rod.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 03-13-2010, 09:05 PM   #6
LEEVON
LEEVON's Avatar
The axle is off but he's got a whole stack to choose from, maybe I should buy them. Does anybody know how much are good doors and fenders worth?
Old 03-13-2010, 09:18 PM   #7
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
The only numbers on a '50 are on the serial number plate in the driver's door opening. There are none on the frame or any other part or at least GM didn't put them anywhere else.
My '54 GMC project is based on a frame swap. I'm doing all my modifications on one frame while all the sheet metal still sets on the original frame. With a little fussing the sheet metal donor is still driver enough to be moved around the yard so its handy this way.
Cabs and beds that have been separated from the frame and running gear are harder to move around. I have one setting on my trailer right now because I can't decide where it should be stored long term.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 03-13-2010, 09:21 PM   #8
addicted2dunes
Same here, except with 57's
Old 03-14-2010, 07:23 PM   #9
solidaxel
solidaxel's Avatar
That was my choice and it worked out great, until I started cleaning things and from there it got wAY OUT OF LINE!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-18-2010, 03:39 PM   #10
LEEVON
LEEVON's Avatar
Ok, so I decided to go get the frame. I looked at mine again and it is solid but has heavy pitting which I hate. His frame is in better shape.
So does anybody local want to tag along or need fenders, doors, axles, hoods, a cab, core supports etc..? He's got a barn full, probably 10 trucks parted and stacked. Cheap, too.
Old 03-18-2010, 10:41 PM   #11
sweet70beast
sweet70beast's Avatar
See if he can load them up and bring them up here and I'll go with you. Dang it!
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
