07-22-2010, 11:55 PM | #1 |
Still plays with trucks
Re: D52 Caliper Rear Disc Brake Brackets
I have seen some newer AWD Astro vans with six lug wheels (the same wheels that came on my 03 Tahoe) so I am assuming they are a 2003 model year or so. Have you looked into using the D52 brackets with these rotors on a 4x4 application?
http://www.napaonline.com/Search/Det...+50014+2014004 They are 1.14" thick and 12" diameter so I don't know if the D52 caliper can handle that for sure. You would think that 1/10th of an inch smaller would be OK.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
07-23-2010, 01:22 AM | #2 | |
60-66 Nut
I guess I haven't paid much attention to the newer Astros. I'll have to check into those and see what style of parts are used. I do already have something in mind for a 6 lug rear disc, but I'm reluctant as I'm not sure how well they would sell. Thanks for the info....
07-26-2010, 12:03 PM | #3 | |
My 67 is sitting on a square body 4x4 half ton chassis so it is 6-lug and I have a set of the El Dorado rear calipers. I was thinking that the 88-98 new body style 4x4 slip on front rotors might work for this. I keep meaning to grab a set from Pull & Save to test out but always run out of time when I am out there. I will look them up on NAPA's site and get some idea of the offset and thickness to see if it is even worth picking up a set to test out.
07-26-2010, 10:26 PM | #4 | |
60-66 Nut
Yeah I was planning on using the '88-'98 K1500 rotors. I've already got the dimensions on them and the brackets will be this style, just a different spacer. I might see about ordering some spacers cut for these this week.
07-27-2010, 11:59 AM | #5 | |
http://www.napaonline.com/Search/Det...50014+2014365#
07-27-2010, 10:42 PM | #6 | |
60-66 Nut
Yeah I've found similar ones from the Savanaha vans. The only problem with putting say a 13" rotor on the back is that you really should run one on the front as big or bigger. That is where it becomes a little more involved and $$. Those Tahoe rotors are really deep.....about 1/2" deeper than the Astro rotors.
07-29-2010, 12:01 PM | #7 | |
Turns out the rotors on the front of the 03 Tahoe are the exact same ones on the Astro van of the same year. Makes them a whole lot more common and easier to find.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars Last edited by 68 TT; 07-30-2010 at 11:26 AM. |
10-23-2010, 09:22 PM | #8 |
got my brackets, i need the years for the parts that i need. like rotors, calipers and things of that nature
08-01-2012, 10:46 PM | #9 |
Torn between 66 and 78
I've been cruising Autozone checking for parts and I'm a little confused. I keep reading the d52's are on 71-87 trucks but the parts differ on AZ's website. I did run across a note on the 84' calipers that says it is for J5 brake system. Is this what we would use?
http://www.autozone.com/autozone/par...vice=234655186 Or will the ones they show for my truck work, I have a 78? |
07-22-2013, 06:28 PM | #10 |
Do you offer a bracket for Dana 60's from 72 C20 using caddy Eldorado calipers? Thanks. Jim
