08-22-2010, 03:12 PM | #1 |
Re: My 86 build
I survived moparfest....lots of cool cars tho....got some looks at some tires, and some connections for ls1 swap!...at a dodge show, who knew?
08-22-2010, 04:15 PM | #2 |
GoatLube Experss
Re: My 86 build
I had thought bout glass'n my dash, after see'n yours I'm definatly go'n to now. the tail looks good too ! good job on all of it !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
08-22-2010, 04:41 PM | #3 |
Re: My 86 build
Hey man, what did you do for the cracks on the dash? Mine pop up like hell, did you sand it all flat then do it? Just curious cause this looks WAY better then buying a stock looking one.
With enough time and money, you can do anything Quoted from my father 1976 C-10 Project |
08-22-2010, 05:14 PM | #4 |
Re: My 86 build
I just broke off piece's of the vinyl till the dash was somewhat level around the cracks and just roughed up the surface to make the resin stick, and wiped everything with wax and grease remover. The speaker holes were all busted out so I covered them up with some aluminum tape, and where the trim piece was, I cut a piece of cardboard to fit in the opening and taped it in. I also made piece to fit where the VIN number opening is to make the defrost vents look the same and save some work.
08-22-2010, 05:23 PM | #5 |
Re: My 86 build
Thanks....I definately recommend trying it!...like I said I had nothing to loose, my dash was cracked and split, and a replacement was too expensive and this way it gives it a custom look.
08-22-2010, 05:29 PM | #6 |
Re: My 86 build
I can't take all the credit, This is where I got the idea from....
08-23-2010, 03:07 AM | #7 |
Re: My 86 build
Somebody needs to do a how-to on fiberglassing the dash!
08-23-2010, 06:56 PM | #8 |
Re: My 86 build
.......wish that I would've taken more pics when I was doing it.
