My 68 stepside build
well to start off i bought this on ebay for 830 bucks. Title says its a 69 but I think it is mistitled. yes the vin matches the title. it has a hand operated ebrake and grille is a 68. anyway here it is as i bought it for 830. pics are straight from the ebay auction.
Re: My 68 stepside build
i drove the inline 6 up on the trailer. it has a 4 speed manual but started life as a 3 on the tree
rust in the rocker panels and the bottom of the passenger core support.
already picked up a new passenger fender as the one on truck was attacked by a bb gun LOL and a new driver rocker
check out the crack in the exhaust manifold. also the 4 speed didnt have a housing cover on it.
gutted the inside and pulled the bed (sanded and spray painted the frame temp to stop rust) which had a sheet of osb in it. After pulling the osb i found this...
Tot Roddin'
Great looking build, good luck with it! And it looks like money well spent...
![]() What are your plans for it?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Under Construction
looks like you got into right, and are making leaps and bounds already...
good luck with your build! Heath
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
going the resto-mod way...I really wanted a fleet side short bed but im happy with it.
1977 Chevy C10 RWD long bed |
well latest progress is I gutted the bed rails and trashed em they was just too far gone with cancer when repop are like 100 bucks a set. Also started to pull the drive trail to clean up the bay and paint. Also ditched the exhaust manifold with the crack on the ear and getting the flowtech part#11510 headers from jegs.
1977 Chevy C10 RWD long bed Last edited by C10NEWGUY; 08-13-2009 at 09:33 AM. |
Got a question guys...what is a good place for a replacement oil pan for the 250 inline?
Update!
Will get pics up soon but as of today.... replaced all 4 wheel cylinders replaced front/rear brake shoes replaced hydraulic brake hoses front/rear pulled heater core and shaved firewall shaved third brake light installed new front shocks cut one coil from front coils installed 6" drop rear coils installed new adjustable rear track bar driver rocker panel install is complete fixed passenger rocker rust USED OEM core support with no rust installed repop passenger side fender I still need info on an oil pan for an inline six???? Is it the same pan as a small block? My pan is shot and leaks like crazy!
1977 Chevy C10 RWD long bed Last edited by C10NEWGUY; 12-16-2009 at 02:20 AM. |
Well the chassis is pretty much done and the inline is getting rebuilt as I type this. The block will now be .040 over. I rebuilt the 4 speed as well. I will get some pics up soon.
HickTown
local junkyard?
1993 Ford Mustang Vert w/ 2.3 1969 Chevy C/10 w/350 1968 Chevy C-20 w/250 1976 Dodge Aspen W/ 225 2000 Toyota Tundra w/4.7 1987 Dodge Ram D-100 w/360 255/70-15 ___________ (oo)══╬══(oo) ‾‾‾‾‾‾‾‾‾‾‾ |
#15 |
I got the inline 6 back awhile ago and have put it back in the truck. The truck is now in the stages of getting into primer.
#16 |
Not on here too much but I have made leaps and bounds as of the past few months....See pics
#17 |
low n' slo
![]() Join Date: Mar 2009
nice progress..
did you do the firewall and frame with the motor and cab on it?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#18 | |
I removed motor and honed it and re-ringed the pistons. Also replaced every gasket from oil pan to carb and rebuilt the monojet 1 barrell. I have never removed the cab but need to change the cab mounts so I will be in the future.
#19 |
Just ordered new front and rear brake drums as well. Im really looking foward to the finish line on this build as it is my first ground up build.
#20 |
new pic of inline 250
#21 |
Just picked up some 18" titan wheels. Will have pics after i bore out center to fit hub.
#22 |
truck is going to paint this week
#23 |
Looking good! What color will it be?
Bryan ![]() See all pics of Project#2=72 here: http://1972c10build.shutterfly.com/pictures |
