Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 12-06-2010, 12:52 PM   #1
Liz
Catchy title goes here..
Liz's Avatar
Lets see your truck!
Pretty much every other area on the site has one. Lets show off those pre 47 trucks! It doesn't matter if its a basket case, someday project, concourse resto or anything between. If you own it, show it off. Post a picture of your truck here.
Liz is offline   Reply With Quote
Old 12-06-2010, 02:26 PM   #2
63 & 64 Bowties
and a few others
Re: Lets see your truck!
I'll go first
Definitely qualifies as a basket case.
This is my 39 1.5t that I have no idea what I'm gonna do with it.
I've got a couple other projects to finish before I start this one anyway.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 12-08-2010, 04:58 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Here's my wife's 41 she inherited it after her Grandpa passed on a few years back from cancer. Her Grandma knew how much my wife loved her Grandpa's truck so she gave it to her. It still lives in grandma's garage, but we take it to shows when we have time. Here are some pictures of the Gold Rush Car Show in oroville back in May.
The red gmc beside it is my work in progress, I have more pictures I will upload later.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-08-2010, 10:21 PM   #4
Jacfourteen
Here's a couple more from the 2009 Gold Rush Car Show.
Old 12-08-2010, 11:21 PM   #5
Bennett68C10
Bennett68C10's Avatar
Some Pics of My Dads 40
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-09-2010, 02:23 AM   #6
Jacfourteen
Nice looking truck!
Old 12-23-2010, 10:15 PM   #7
RANDY COX
RANDY COX's Avatar
Been a while since Iv'e been on here or visited.Had alot going on in the past,But I do miss my 41 1.5 ton,my 90 burb4x4,my 70 burb 4x4,I just have the car now 48 Fleetline
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-19-2011, 03:29 PM   #8
papajohn51
Project 41 on s10 frame in progress
papajohn51 is offline   Reply With Quote
Old 01-19-2011, 11:25 PM   #9
CURSED GEARS
Don't know if this will fly on here, but heres my 39 Chevy. Started with just the cab. Still in progress.
CURSED GEARS is offline   Reply With Quote
Old 01-28-2011, 06:53 PM   #10
truckeez
late 30's ford frame?
truckeez is offline   Reply With Quote
Old 01-28-2011, 10:03 PM   #11
CURSED GEARS
Home built frame.
Old 01-29-2011, 09:07 AM   #12
63 & 64 Bowties
and a few others
Very cool. I love the rats. Any plans to chop it?
Old 01-29-2011, 01:23 PM   #13
mater63
mater63's Avatar
randy what's a complete 48 2 door fleetliner worth? i have a friend who wants to sell his (basket case) chrome & glass are all good
mater63 is offline   Reply With Quote
Old 01-29-2011, 04:08 PM   #14
truckeez
Home built frame.
Heres some pics of my diabolical plann First pic is a 35-40 ford frame its got the right drop for the fenderless rod. The second pic is of a C% vette front crossmember assembly jig. if you look closely the vette aluminum engine cradle is sandwitched between and the lower a arm thru bolts are there --the upper a arm mounting bolts ar on the outside uprights. Now i cut the fixture in half and removed approx 6" and slipped one size smaller tube inside and can adjust it and make a crossmember for any track width from 37 to 43".
the copy machine composite cab pic is what my cab will look like, with a 4" front and rear chop--(some like to take out the extra 1/2 " on the front of these cabs). The rear wall is bumped back about another 3 1/2". I hope to have composite panels --The roof and backwall Done and avalable by june for guys that dont want to cut up two cabs and do a lot of welding to get their cab to this point. If I also do a cowl--The 3/8 bead going around the side and top front edge will be smoothed off,
and guys could go thru their states procedure and get a replica vehicle title,
instead of the regular steel cowl--broadway title BECAUSE these are often found with no number tag to go by/ and they often went by engine serial # or chassis # in some states and they automatically make you got to the govt employed (state dmv)inspector and get a vin assigned to you anyway.
Old 01-31-2011, 05:50 AM   #15
CURSED GEARS
Probably chop it after I get it on the road after a while. I just want to drive it soon. Its been going on 5 years since I started it.
Old 01-31-2011, 03:48 PM   #16
truckeez
Talking Re: Lets see your truck!
I got the 36 gmc hood nose and grill for mine- and No--No origonal will be harmed to do mine, 36 was the first yr of the GMC half ton and it would ba a sick puppy who would mess with a stock one--There are 1.5 ton stake bed ones of someone searched long and hard enough.
I feel that people should spend their vacations in Nebraska--lookin to see what farmers got in their tree rows
Old 01-31-2011, 05:55 PM   #17
63 & 64 Bowties
and a few others
Don't know if you've seen this before. But, this is one unique way of doing a chop. More work, but I really like it because you don't use the filler piece in the roof this way....
http://webrodder.com/article.php?AID=26&SID=16&CID=7 (part 1)
http://webrodder.com/article.php?AID=27&SID=16&CID=7 (part 2)
Old 01-31-2011, 06:27 PM   #18
truckeez
Thanks for posting that thread it looks real cool. i have done my fair share of this--- One of my cabs is One of a kind---
Most guys do not know but the 36 is more different than the 37-8 than they know The rear window opening looks the same-it is the same hole--but its positioned 2" lower on the 6 , also the windshield is 12" on the6 and 14" in the 7-8 and I think if someone is taller from the waist up the 37-8 gives a better view and guys dont feel like they have to crowch down in the seat to see--im a shortie so peering over the dash top is the problem.
anyway i have a 37-8 with a 6 roof top spliced-its a hybred of both.
Old 01-31-2011, 06:31 PM   #19
truckeez
and another thing--Im not chopping up two cabs to do this this time, im splashing off them to make temp plaster molds to get the parts needed So i dont cut up good cabs ( but I know a guy who has some he torched the hinges off of)--I hate it when that happens.
Old 01-31-2011, 08:11 PM   #20
CURSED GEARS
Thanks for posting that, It was a good read!
Old 02-02-2011, 09:20 PM   #21
Todd68Chevy
Todd68Chevy's Avatar
I have a build thread on here but have not worked on the truck for a while. I did some work last summer on my 68 last summer and hope to get back on the 46 when the weather gets better. Started life as a 1 1/2 ton firetruck and now is getting the cab stretched 6 inches and placed on a 93 S10 chassis.
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 02-11-2011, 07:47 PM   #22
Muleman100
Muleman100's Avatar
My 1941 Chevy 3/4 ton ( registered as a half ton )
1960 235 in line six with an Offenhauser dual intake with two single carbs
Original 4 speed granny transmission
1982 S10 rear end to get down the road better
http://i1089.photobucket.com/albums/...0/S4010013.jpg
http://i1089.photobucket.com/albums/.../IMG_37941.jpg
" I never think of the future. It comes soon enough " - Albert Einstein
Muleman100 is offline   Reply With Quote
Old 03-06-2011, 11:08 PM   #23
zicc1835
zicc1835's Avatar
Cool Re: Lets see your truck!
new to site yesterday and was focused on my 67 looked around to day and saw the pre 47 page well here yah go MY36 SHE RUNS/DRIVES GOOD WILL START THE RESTO THIS SPRING look forward to learning and sharing info well lets see if i can post some pics......
zicc1835 is offline   Reply With Quote
Old 03-07-2011, 10:03 AM   #24
63 & 64 Bowties
and a few others
My all-time favorite year.
Old 03-07-2011, 02:21 PM   #25
CURSED GEARS
Thats one cool truck zicc1835. Whats your plans, full resto, or hotrod?
