Old 10-18-2011, 01:30 PM   #1
67gmcstepside
Cowl water drainage holes - where are they
I washed the truck today and water was pouring out of the kick panel vents. It's been parked under a pine tree with the cowl off and it looks like the drainage holes are clogged by pine needles. Where are the holes that drain the water to the bottom of the fender. I was just about to install the new carpet but now with this new challenge that we have to wait. Any information would be appreciated, thanks.
don
67gmcstepside is offline   Reply With Quote
Old 10-18-2011, 01:51 PM   #2
steinepstein
Re: Cowl water drainage holes - where are they
They are located directly below the kick panel vents. I'd remove that vent and stick your hand in there and see if you can remove stuff by hand and the rest blow it out with an air gun.
Jon
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216
steinepstein is offline   Reply With Quote
Old 10-18-2011, 06:51 PM   #3
67gmcstepside
Thanks Jon, the PO must of done some patching because I don't feel any holes below the air vent. Maybe I need to drill some. I'll play with it this weekend. Thanks again
Old 10-18-2011, 08:23 PM   #4
steinepstein
It's not really a hole, it is more of an open seam between the cowl sheetmetal and the cab sheetmetal, it's quite large, you would notice it. That would be weird if it was filled in, I could see how you could have a lot of water draining into the cab if that were the case. Good luck.
Old 10-19-2011, 06:32 AM   #5
67gmcstepside
So this open seam should be right under the air vent? If you stick your hand through the vent your fingers should feel tis opening?
Thank you very much as I think I know what needs to be done.
Old 10-19-2011, 09:07 AM   #6
steinepstein
I'll get you a picture and upload it tonight.
I feel like you could get your hand in the vent hole and find the gap.
Old 10-19-2011, 10:41 AM   #7
67gmcstepside
thank you very much. A pic will go a long way. Last night in the dark I felt around inside the vent hole and it felt like ther PO patched the area with roof cement. I probally will have to dig it out.
Old 10-19-2011, 11:08 AM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: Cowl water drainage holes - where are they
If you jack the side of the truck up and look under the fender you will see the gap where all the water runs out at. You shouldn't have any problem finding it at all if it's closed up as you say then yea the water will spill over to the cab.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-19-2011, 11:17 AM   #9
mpotts64
mpotts64's Avatar
I put a 12" metal blade on a sawzall and reached in through the door and cut the whole bottom out of that box, now, leaves, pinestraw, etc fall right on through, no holding water and it works well
No one ever fell to the top of a mountain.
When asked why I work on old trucks, I tell them: Been married 27 years, sons are pretty much gone, don't like the wife anymore and don't have a girlfriend, so, gotta do something, the old trucks are cheaper and less drama than a girlfriend -
mpotts64 is offline   Reply With Quote
Old 10-19-2011, 01:10 PM   #10
treveiger
treveiger's Avatar
I'm trying to picture it, do you have any pics?
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 10-19-2011, 01:14 PM   #11
mpotts64
mpotts64's Avatar
I have not taken pics of it but I can, it was not hard at all to do, just open the door and go in the opening between the fender and door post of the cab, between the hinges, start close to the side and cut up and out until you run out of metal, when you open the door and look in, you can see the box, just don't cut the side out of the cab,
now, I must say, I do not know about the all the factory a/c setups on these trucks, but I think I heard someone say the side panel vent is actually a recirculation vent for the factory a/c, maybe someone can confirm this, if so, you probably do not want to cut that box
Old 10-19-2011, 01:28 PM   #12
dfwright
dfwright's Avatar
Here's a picture of mine I took while I was repairing rust. You can see the drain hole in the back corner. Ignore the giant rectangular hole, as I was cutting out rusted metal there --- but you can see the triangular drain hole in the corner.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-19-2011, 01:32 PM   #13
67gmcstepside
Guys, this is great!!! I now know exactly what I have to clear to get the water to run out instead of in the cab. I apprecate all these responses!!!
Old 10-19-2011, 01:36 PM   #14
dfwright
dfwright's Avatar
Yes, that is the drivers side in the photo
Old 10-19-2011, 01:37 PM   #15
71blazerdetroit
Yes that's driver side.
71 Blazer, 350/700r4/241 1 tons dana 60 14 bolt 5.13's locked
71blazerdetroit is offline   Reply With Quote
Old 10-19-2011, 03:27 PM   #16
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
When you get ready to reinstall the cowl,put a screen under it.Some make one from HD stuff or most vendors will carry them.It will help keep the crap out so it doesn't clog those drains.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-19-2011, 03:43 PM   #17
RenoKeene
Florida Edition
RenoKeene's Avatar
Here is a shot of the trash screens I got from LMC, pretty nice really and not much $$. BTW A/C trucks have a vacuum operated flap in the cowel on that side that opens for fresh air.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 10-19-2011, 06:18 PM   #18
67gmcstepside
Looks like the PO thought he was fixing a rust problem and replace the entire air vent box but forgot to add any drainage holes. I wiill have to go with mpotts attack and cut out the bottom of the nicely sealed air box.
Thank you all for your time responding to my inquires.
don
Old 10-19-2011, 06:33 PM   #19
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Yes we've all been there, in the dark feeling around inside trying to find the hole/gap...and how we wished a buddy could have shown a picture of where to find it.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 10-19-2011, 07:15 PM   #20
67gmcstepside
Well said!
Old 01-13-2021, 03:50 AM   #21
sinannasirli
Hi, i know this is an old thread but easier for all for me to post here..
i noticed two holes, one in each side below the cowl area..
Are they a somehow added by PO, to drain the water (strangely into the cab) or
should these holes be blocked by a rubber plug etc?
Picture belowtaken from inside the glove box)
Istanbul - Turkey
1969 Chevy 4x4 Suburban - i6 250 ci
1953 Willys CJ-3B - 1969 Opel GT
1996 Lotus Elan s2 - 1993 Lotus Esprit s4
1995 Maserati Ghibli - 2000 Porsche Carrera 4
1958 BMW R26
sinannasirli is offline   Reply With Quote
Old 01-13-2021, 04:00 AM   #22
HO455
HO455's Avatar
I believe those are the factory holes to allow condensation on the inside of the windshield to drain. You should be able to see them just below the windshield gasket on each side of the dash.
RIP Bob Parks.
Old 01-13-2021, 09:04 AM   #23
sinannasirli
Thank you.. that would make sense.. i just replaced my cracked windshield, and it was not the best fit... so i should probably try a sealant job?
Istanbul - Turkey
1958 BMW R26
Old 01-13-2021, 11:16 PM   #24
Peanut74
Here are a couple pics of the factory cut as discussed above.
My fenders are off so pics were easy to take. The A-pillar I to the right of the cut.
1967 C10 "Snowball" (Currently in a million pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer)
1971 Chevy Blazer (Sold it)
Peanut74 is offline   Reply With Quote
